Old 11-26-2018, 05:10 AM
yowie05 yowie05 is offline
Thx guys how to check\replace the right side crank seal? Need to split the cases? Not afraid to do the work myself,pretty handy with the spanners. I?m running ATF in the tranny.
2T oil is maxima 927
AS1 38 carby
Thanks guys, food for thought.
Old 11-26-2018, 05:41 AM
Davehuge's Avatar
Davehuge Davehuge is offline
No, no need to split crankcases and no need to remove engine from the frame.
It can accessed by removing water pump and right hand side engine cover/clutch cover.
Old 11-26-2018, 06:58 AM
Sweet same as adjusting power valve preload tension. What?s best way to pull seal out? Tools And such needed. I?ve only ever done bottom end b4 so all seals were take out with screw driver whilst cases were split.
Thx
Old 11-26-2018, 10:45 AM
Davehuge's Avatar
Well, there's a bit more to it than that. The seal is behind the primary drive gear so you'll have to hold the clutch basket to loosen and remove the nut on the end of the crank.
I've done this job on many other 2 strokes but never on a GasGas, maybe someone else can provide more detailed info.
It's advisable to use the correct tool to hold the clutch basket, they normally look like this...
Old 11-26-2018, 11:32 AM
Neil E. Neil E. is offline
You can also hold the gears the old fashioned way - a piece of soft metal wedged in the teeth. Or make your own tool by riveting an inner and outer clutch plate together.
Old 12-26-2018, 10:00 PM
well bit of an update on my bikes issues. after replacing both of the crank the seals, there was no change. all good must be jetting then so used every main jet from 165 to 185 and no change at all. well must be a spark issues then. recently i purchased a few bits from an 07 model 250 a guy was wrecking. he is on this forum pretty sure its Tomac, thx for the great deal. anyway i got the stator and CDI plus some other bits Vforce 3 reeds and block wich i placed on bike but made no difference, old ones were a bit bent leaving a gap so thought why not as these ones in good nick. still same issues of running ok on the 0 to half throttle when band about ti kick in then nothing, woulnt run at all on high revs/throttle. well i was planning to run the duel mapped 07 CDI so put that and the stator on as didnt want to cutwires.
well bugger me either the stator or the CDI was the issue, thing fukn rips now. heaps of power every where, so im using
NECJ clip 1
42 pilot
175 main
not sure on AS but its about
idles fine, went for a 4 hr ride this morning and its a totally different bike, no spooge running Maxima Castor 927 at 50:1
a little concered that there is no spooge coming out the pipe but there is oil coming from the power valve line, just not heaps.
Anyway thank you everyone for the help, did so much reading of this forum to try and get ideas and well its paid off.
EC300 Jetting Help Hicksi Enduro Intake/Carburetion - 2 stroke 9 09-15-2014 02:58 PM
New to me 04 ec300...jetting help 04gasgas Enduro Intake/Carburetion - 2 stroke 10 02-12-2011 05:08 PM
ec300 jetting Steve ROC Enduro Intake/Carburetion - 2 stroke 4 04-26-2010 08:49 PM
ec300 jetting moff747 Enduro Intake/Carburetion - 2 stroke 8 01-08-2008 03:21 PM
04 EC300 jetting? DWreck Enduro Intake/Carburetion - 2 stroke 13 11-26-2006 08:12 PM
