Old 01-23-2009, 05:12 AM
Eugene Eugene is offline
Default '06 EC300 Rear wheel bearings
The manual is a bit "vague" as to the vendors part numbers for the bearings and seals. Our local dealer collapsed so we are in a bit of a tight spot in SA right now, so herewith the part numbers for the bearings (I used SKF products)
Parts Manual reference SKF Number
Item 9 (small seal) 25x42x7 CC
Item 44 (big seal) 32x42x7 PU
Item 8 (small bearing) 60042RSR (2 Required)
Item 59 (big bearing) 60052RSR
Hope this helps anyone in a fix.
'06 EC300, '06 FSE450, both 'tricked & treated"
Old 01-29-2009, 02:50 AM
jiauka jiauka is offline
Hi are you sure item #44 is 32x42x7 ? I think it should be 25x47x7
have fun,
j.
Old 01-29-2009, 04:16 AM
That's what I bought and fitted to my '06 EC300. Running fine, no problems
Old 01-29-2009, 08:18 AM
Good, Ec '04 is different.
have fun,
j.
Rear wheel bearings on 03 kendunn Enduro Chassis & Body 8 01-06-2011 05:43 PM
Rear Wheel Bearings cladoo Enduro Chassis & Body 2 11-18-2008 10:14 AM
05 ec 300 rear wheel bearings burgo General Discussions & Announcements 1 06-08-2008 03:32 AM
rear wheel bearings smithys ec250 United Kingdom 3 04-23-2008 04:01 PM
Rear Wheel Bearings gasIdaho Enduro Chassis & Body 7 02-14-2008 08:34 AM
