Old 08-03-2009, 07:48 PM
Brian VT Brian VT is offline
Default oil drain bolt crossover ?
I looked through the "crossover parts" section.
I searched "oil drain bolt". (Try it. You get 11 pages of...)
I've changed the oil at least 50 times on this bike. No problems. I managed to strip the Allen head tonight.
I don't want to remove it until I have a replacement. Would another brand's part cross over or can I get a suitable replacement at a hardware store ? If so, what's the best method of removal, EZ-out ? I know it's not very tight in there.
Help ! I'm leaving Wed. night and hope to not have to put 2 days riding on 100-mile-old oil.
Old 08-03-2009, 08:35 PM
Go to your friendly Ford dealer and talk to one of the diesel techs.
Tell him you want the plug that goes into the top of the high pressure oil pump on a 6.0L motor.
Or, PM me your address and I'll send you one.
Use a Torx bit to remove the drain plug.
Old 08-03-2009, 08:44 PM
Thanks for the lead on the plug. I'll stop there tomorrow. The Torx is a good idea too.
Old 08-03-2009, 08:50 PM
You're welcome.
I'm a diesel tech at a Ford dealer, when I saw that bolt a light bulb went off. Brought it home and it's an exact match, even has the O-ring built in.
No magnet though, which is a good thing, due to the fact they can come loose.
Old 08-03-2009, 10:43 PM
gasser's Avatar
gasser gasser is offline
You already have a suitable replacement - it's the oil fill bolt up top. It's exactly the same except for the magnet. You can use the bad one for the fill bolt after you cut a slot in it for a common screw driver. Do put the good bolt in the bottom, order a new one, then change the bolts around on your next oil change.
Old 08-04-2009, 05:33 AM
LOL. I was wondering that while lying awake in bed last night and I was going to check the IPL or ask on here this morning. Thanks !
Old 08-04-2009, 08:11 PM
Leo's Avatar
Leo Leo is offline
SEW Eurodrive manufacture of gearmotors have awesome steel drain bolts too
www.endurohp.eng.br
Sherco ST300 2015 (Trials)
https://www.instagram.com/leocm74/
Brasil!
oil drain bolt in case jyellard Enduro Engine - 2 stroke 11 10-13-2009 04:39 AM
2T drain plug wence Enduro Engine - 2 stroke 0 10-13-2009 04:28 AM
oil drain plug nitroman Enduro Engine 4 stroke (including EFI & Exhaust) 1 08-18-2009 07:32 AM
Oil drain plugs that work! GGLoops Enduro Product Reviews 6 03-03-2009 04:22 PM
Oil Drain Plug MIKEWA Enduro Engine - 2 stroke 4 01-27-2007 06:19 AM
