#21
I did another oil change last night and flushed it out, then put new oil in and about 200ml less than usual and, then let the bike idle for awhile then rode for about 10 - 15 minutes around the block. No white gunk! but I will have to ride a lot longer and harder and find out. If I still get some, then I'm gonna check water pump seals and go from there (crossing fingers). Thanks for all your help everyone. Chris
04' GG FSE 450 Live Easy, Ride Hard! |
#22
If the water pump seals were leaking, the oil will be milky.
I think your rings are worn. You are getting excessive blow-by past the rings. The crank case ventilation system can't keep up, so it's blowing out the vent hose. Coasting down long hills can cause this also. |
#23
I'll post with an update in a week. Thanks for all your help everyone! Crankin04
Thread Tools | |
Display Modes | |
Oil leak from breather pipe TXT pro 250 | jamesukm | General Discussions & Announcements | 0 | 04-22-2010 12:59 AM |
Crankcase Seal Removal | gasser | Enduro Engine - 2 stroke | 4 | 10-06-2009 12:47 PM |
Crankcase vent blocked | kendunn | Enduro Engine - 2 stroke | 2 | 10-06-2009 12:37 PM |
pv breather | jprh | Enduro Engine - 2 stroke | 5 | 02-21-2009 08:38 PM |
Crankcase steam hose | Alan | Enduro Engine 4 stroke (including EFI & Exhaust) | 8 | 07-06-2007 10:15 PM |
