Old 08-28-2010, 01:13 PM
2whlrcr 2whlrcr is offline
Default Lowering Rear Brake Pedal Height?
Is there anyway to lower the rear brake pedal more? I have mine all the way down and it's still 1/4 higher than my pedal. Plus in this position there is very little free play and the brake is like a light switch. I am used to running my pedals much lower and have never had an issue setting them up, until this bike.
If you cut the the threaded adjustment rod and shorten it, will this help move the pedal down and still give you adequate free play? Any thoughts?
Thanks
Old 08-28-2010, 02:00 PM
HydroDog's Avatar
HydroDog HydroDog is offline
I ended up cutting mine and welding a 3/8" alum. spacer in to lower it.
07 GG EC 300
05 KTM 250 exc
99 KTM 640 enduro
Old 08-28-2010, 03:21 PM
nambo-trev's Avatar
nambo-trev nambo-trev is offline
i just took my rear clevis off and used a hack saw and cut another 3/8 off. this will allow you to lower it quite a bit more!
trevor
Old 08-28-2010, 04:50 PM
You cut the threaded rod 3/8"?
Old 08-28-2010, 05:15 PM
Yes, I too have been doing this on my GGs since '00.
Old 08-29-2010, 10:18 AM
spizz spizz is offline
Let me know how it works out for you 2whls, then I`ll do mine.
Old 08-29-2010, 10:34 AM
nambo-trev's Avatar
yes i cut the threaded rod, you dont even have to take it off just chop a little piece of with it still on. much better adjustability now
trevor
Old 08-29-2010, 01:32 PM
Yep, that's the ticket. I just took the pedal off and left the rod attached to the reservoir and used a dremel and cutoff wheel. I took off 3/8" and need to test ride to see where I'm at.
On a side note, I remembered my Honda has Nissin brakes and started comparing the two. Calipers look very similar, but are not identical the castings are slightly different. I didn't have the height issue with my Honda and the systems are mechanically the same. The difference is the Honda has a longer cage to the clevis and therefore more adjustability. Also the Honda has more free play in the clevis, but this could just be from wear.
Old 08-29-2010, 02:15 PM
I`ll give it a try.
Is it running ok now?
Old 08-29-2010, 06:17 PM
I`ll give it a try.
Better, but not perfect. I've got some other needles ordered and will give them a try.
Rear brake pedal HydroDog Enduro Chassis & Body 0 03-09-2008 10:48 PM
2002 rear brake pedal kevin849 Enduro Chassis & Body 5 03-07-2008 12:08 PM
Rear Brake Pedal Rick Enduro Chassis & Body 4 01-28-2008 01:57 PM
