Rear Engine Mount
1st of all just thought I'd say hello to all you peeps.
I've just bought a '98 six days EC250 last weekend and already got it 75% stripped down as I'm gonna rebuild it,Im having trouble removing the rear engine mount (the one that goes through the frame with 2 nuts either side) I've soaked it in wd40 and got both nuts off,however I cant seem to shift it, I realise that it probably hasn't been out in 13 years but is there anyway it comes out I should know about?? Obviously I've hit it with hammer form both sides and when that didn't work I got a BIGGER hammer but again still not moving. Any Ideas would be greatly appreciated as I just want to get it completely stripped so I can start on the frame. |
I ended up with the frame in a hydraulic press, took 15 metric tonnes before it loosened, and that was only after one year. Cant imagine what 13 years might do..
PB Blaster works 100 times better than WD-40. Trust me and try it, it has a catalyst in it that seems to dissolve oxidation which is probably what you're dealing with.
+1 on PB Blaster
Thanks to FLY Racing. Last edited by motogroove; 07-21-2011 at 01:35 PM. |
Hi thanks for the replies,pb blaster i've never heard of it before i'm willing to try it just got to locate some first of all .
Just checked it out see if it's available in the UK but it looks like US only looks like i'll have to order some in
I've used "plus gas", which is available here in UK
http://www.thesitebox.com/lubricants/plusgas.aspx
Gas Gas EC 300 '06 BMW F650 |
sometimes some heat helps break things up.
plus i think the wd, or whatever, is drawn to it. but not to much for too long. you can heat up the motor itself a little to help get the wd in there too. also, if you dont try to drive it out directly... i mean if it moves a litlle in one direction, then send it back in that direction... like how you rock a car out of the snow.
2002 Husberg FE650e 2006 GasGas EC300 2014 Sherco SER300 2014 Beta Evo Factory 300 |
to be honest it looks like im gonna have to heat it up,however it does spin around I can hear lots of grit/rust in there.
I dont know if this is relevant but in between the frame and the swinging arm that moves as well at both ends,so I dont know whether thats got some factor as why it wont knock out. Im a bit nervous about taking to a garage that has a oxyacetelyne tourch to heat it up in case they damage the engine casing |
Take your time and don't go mental at it, and it should be ok. Don't do what a mate of mine did to his suzuki drz, and cut the swingarm off to release the bolt
'00 Montesa Cota 315R '13 Husaberg TE 300 |
Thread Tools | |
Display Modes | |
07 EC250 Cylinder head engine mount | WTEC | Enduro Engine - 2 stroke | 4 | 09-02-2009 07:12 AM |
Rear linkage brackets lower mount | 3hunerd | Enduro Suspension | 2 | 10-16-2008 09:42 AM |
Exhaust Clearance at rear pipe mount | REVERUP | Enduro Engine - 2 stroke | 12 | 01-15-2007 05:43 PM |
