Questions about my new xc-e
I have just assembled my first gasgas 2012 xc250e and i have so many questions. Has anyone else had issues? I only have the warrenty card and nothing else? The only way to kill the bike is from a keyed switch,The button on the right (labeled kill switch) is actually the start button. I have a trail tech Hi/low -kill switch that i was planing to install.And was wondering if anyone has done the same?
I have the same bike and have added a kill switch. There are 4 wires that come out of the key switch, can't remember the colors but you can wire two of them to a kill button and leave the other two on the key switch if you want the key switch to control when the starter button is live. For the kill button you want the two wires that have continuity when the switch is off. Otherwise you can wire the other two together and the start button will remain hot at all times and you can removebtevkey switch entirely, or you can put some other switch between them.
The wiring diagram for the 2011 six days model, I think it was, helped me a lot. You can find it on the gas gas Spain website. Take the key switch off the bike and test the wires with a continuity tester and the key switch in off and on position. You want the two wires, for the kill switch, that have continuity when the key switch is in off position. |
switch issues
Thank you, Steve and TBUBBA. I will give it a go later today.
handlebar switch issue
A few months a go I asked about eliminating the Keyed switch. After reading
the last thread, I could not bring my self to cut the wiring harness. So I ordered part # ee10000043012 from gasgas. this unit will not plug into my harness either. Mine is an e-start. not to mention it has turn signal & horn button which I dont need. Perhaps this the only configuration? Do the 2013s have a similar switch? Thanks in advance. |
They should ditch the key switch, as well as the steering lock for US bikes. One more place for water to go, and no need on a race bike. I understand the point for the Euro market where they are street ridden.
Switch issue
GMP,
I agree about the steering lock and the keyed switch. The fellas at motocross center are saying I need a different wiring harness. If i want to plug and play. No really what I wanted to hear. |
I have a 13 and i took off the key switch and e-start the only problem now is the brake lights don't work just have a tail light. Behind the headlight there is a bunch of wires and plugs which I am sure has the brake light wire somewhere in the rats nest
2013 xc 300 |
switch issue
Nick,
So you removed the keyed switch along w/ the e-start (completely) ??? I though the 13' didn't have a keyed switch??? E-START that is. |
Yes I removed e start and the key switch
2013 xc 300 |
Thread Tools | |
Display Modes | |
Questions and help please? | darrenrd | General Discussions & Announcements | 4 | 08-01-2011 11:24 PM |
AC and DC Questions | speedy08 | Enduro Electrical & Wiring | 2 | 05-07-2011 10:34 AM |
Gas Gas MC 125 questions | MDN91 | Enduro Chassis & Body | 4 | 08-31-2008 05:54 AM |
GG FSR 515 Questions....what to do | pbspecial | General Discussions & Announcements | 9 | 04-14-2008 09:11 PM |
Questions About The 07's | Boomhauer | General Discussions & Announcements | 4 | 04-07-2007 12:17 PM |
