#91
I run a 38 PJ, 175 main and A/S 1 1/2 turns out. Carb is a Air Striker 2, 38mm, #7 slide, CCK in clip #3 from the top. I ride mainly around 2000 to 4500 ft. And there is next to no humidity here. My bike ran okay with the N1EF needle, but a little on the rich side. Much smoother power with the CCK, very linear, no distinct hit. Gonna have to wait another month to try the N3EH as they're on backorder. I did have to turn my idle up slightly with the CCK.
#92
jetting
4 bikes all four 300s 03 05 06 09 mine and my sons p42 main 178 cck needles clip 2 or 3 down depending on temp never any jetting problems ever! 50 to1 amsoil 1000 to 2500 feet this works for us! thanks
#94
The carby has changed, for some 2010's. The 2011s have been identified as some having a 36mm, others 38mm.. Just a few more variables to throw into a the mix.
#95
I'm the original OP.
After a ton of tweaking, here's the dilemma. My current workable setting: 15C - 750' ASL 2010 EC300 with Airstriker I 38 Pilot JD Blue needle - 3rd clip AS 2 turns Idle screw 4 turns from full in (~15 turns availble) 7 slide 178 main Here's the deal. Like so many others I'm fighting an idle screw that has to be turned way in. With the above set-up I can get the bike to run well. Steady idle, barks off the bottom (a little too much for the tight woods stuff), the main is probably a little fat but I haven't had the chance to run much WFO stuff - it's been a soggy Spring here. I don't get why the idle screw has to be so far in? This has been the case since I got the bike. With my current set-up I don't think it's a case of 'ticking/pulling over' - the idle screw pushing onto the slide. I know some say I need a leaner needle. I've tried the leanest needles I can get my hands on (JD Red) and still the idle is way turned in. I'm waiting on a NE3H needle. When I compare a N0ZH needle that I have, the JD needles (blue and red) are larger in diameter through the body and at the tip. I don't think a leaner needle - if I could find one -is gonna solve the problem. The 38 pilot has got the idle screw out more than any other set-up. I tried fatter pilots (40 - 42 -45) and the idle problem got worse and they were way too rich. With a 42 the bike would start cold without choke, and loaded up after a short time at idle. The 45 was worse. The 40 seemed ok, but the 38 gets the idle screw out more. I'm a little confused? The bike seems good with the present set-up, but I don't know why the idle screw has to be so far turned in? I don't have any security torx screw bits to check the pilot block for missing o-rings - see this - http://www.gasgasrider.org/forum/sho...highlight=idle A friend gave me a B5EF needle. It's 2-3 mm longer than every needle I've tried yet - that's gotta be way leaner. I'm gonna give it a go just for shits and giggles. Otherwise I guess I'm gonna just accept that this beast has a way turned in idle. Anybody have any ideas? Thanks, Jason. |
#96
I admit mine has to be turned in quite a bit to sustain an idle, but i still have a range of tunability. I think the problem is more so when you have it screwed in to the stops and still can't get an idle.
As stated, you're still too rich on the needle diameter. (The small straight before the taper, that overlaps the pilot circuit). This is evident by the smaller pilots, and adjustments with airscrew making things better. In my opinion though, if you're happy with how the bike is performing and it will maintain an idle hot and cold, then be happy with it I'm changing from my N3EG to a N3CH to see what difference it makes on mine, and if I can be bothered i might even try the N3EJ. Will get back with the results. |
#97
I have the same bike with the same carb, and I agree with Jakobi on the needle being too rich at the idle portion only. The length of the needle would not have an effect on the idle. Just be careful that the longer needle does not bottom out in the main jet and prop up the slide.
I tested a bunch of needles, CCK, CCL(mismarked I found out... ) N1EF, N8HG, BGL, ECL. I found that the stock diameter needle, N1EF is 2.705mm in diameter. Apparently for whatever reason this needle is too rich on the upper straight portion for the bike to idle right as it supplies too much fuel. The answer to your idling questions is to get a needle with the larger diameter straight portion of at least 2.715mm or larger. That would be the same as an N1EG. Another step larger would be an N1EH at 2.725mm. Going larger on diameter on the straight restricts how much fuel comes up through the needle orfice. This diameter only affects the idle area. I found that I was flooding the bike with fuel at idle no matter where the idle screw was. It was so rich that the pilot air screw had really no affect on things. Also with the weather getting hotter out the rich idle condition will magnify itself even more. I'm not saying you have to run an N1Ex taper however just get the needle straight diameter lean (thick) enough and go from there.
'10 EC300 -- very happy |
#98
so what you're saying is a ccm/ddm will most likely idle better than a cck/ddk
if air screw/idle screw has no effect - it is in fact 'k' diameter (2.7mm) is too rich of a needle. many people are chasing float height to fix idle issue...
07 ec300 was 00 xc200 now a 00 xc300. now parting out. 99 ec300 (now a pile of parts which are for sale) Stainless Cycle - Motorcycle Bolt Kits www.stainlesscycle.com |
#99
Who's tried a #8 slide on a new bike, especially 300's. Might be worth a shot.
07 EC 300 (under 500 miles, selling soon) 97 KTM 250 EXC (sold) 2016 Trek Remedy 29er |
#100
The idle issues for me have been fixed with a combination of different things.
Float height: I had to lower my floats about 2-3mm, just so gas doesn't drip out on the sidestand. Needle diameter: the stock needle, 2.705mm in diameter passes too much fuel at idle. The 300 pulls a lot of vacuum due to large displacement and if you could measure intake manifold vacuum at idle it would be more than a 250 and more than a 200cc bike. The #7 slide I have is notched at the center bottom and lines up with the needle jet block shroud creating even more vacuum in that pocket where the needle sticks out of the needle jet orfice (emulsion tube). I believe that the pullover from the thin needle contributes to the rich idle condition. Think about it. When the motor is cold it may idle fine but after you ride for a few miles and it heats up, it idles really low or just stalls out. So with the throttle closed, a thin needle, higher than necessary float height, the massive vacuum signal from the 300cc of displacement, and the notch in the slide along with a hot engine that doesn't need as much fuel at idle, yeah, I think the recipe is there for a hot no-idle situation. I think folks may have sucess fine tuning the pilot jet, needle diameter and air screw. I didn't want to spend the money on a #8 slide as of yet. The K and L diameter needles ran fine in my bike when the temps were in the 50-60 degree range. At 90 degrees, I needed a thicker needle so it would idle again.
Thread Tools | |
Display Modes | |
2010 250 EC Jetting. | enduro1 | Enduro Intake/Carburetion - 2 stroke | 13 | 08-19-2010 05:56 PM |
2010 Sachs fork factory compression stack specs(ec300) | bergerhag | Enduro Suspension | 9 | 07-01-2010 11:18 PM |
2010 EC250 Jetting | WTEC | Enduro Intake/Carburetion - 2 stroke | 1 | 03-26-2010 09:41 AM |
jetting for new 300 racing 2010 | fabulous furry | Enduro Intake/Carburetion - 2 stroke | 9 | 08-11-2009 09:28 AM |
04 EC300 jetting? | DWreck | Enduro Intake/Carburetion - 2 stroke | 13 | 11-26-2006 08:12 PM |
