#101
Good work mate, couldnt have explained it any better myself |
#102
I found this link on this site some time ago, it's the most comprehensive info i've found on keihin needles http://www.sudco.com/vol33/135-136.pdf
Wish there was something similar for the N3-- range of needles, the best i've found is in a yz 250 owners manual, it says a N3EH is richer on straight section than a N3EJ and that a N3EW falls in between the pair of them, but it doesn't state what the actual diameter's are. The final letter indicates straight section diameter, but it obviously doesn't follow alphabetical order? Last edited by rod; 04-26-2011 at 06:18 AM. |
#103
Yaaaaaah
2010 300. Just switched from a n1ef to a n3ch: went for first time quick ride today-bike has come alive . Sorry, pilot/main settings written down at home.
Will update as i put on more miles this week |
#104
Yewww!! look forward to the updates!
#105
SIZE: P/NO Dia. NOZF 13383-37EB0 2.705mm N1EF 13383-37E60 2.705mm N0ZE 13383-37EA0 2.695mm N1EE 13383-37E50 2.695mm NOZD 13383-37E90 2.685mm N1ED STOCK NEEDLE 13383-37E40 2.685mm N0ZC 13383-37E80 2.675mm N1EC 13383-37E30 2.675mm N0ZB 13383-37E70 2.665mm N1EB 13383-37E20 2.665mm seems to indicate f=2.705mm E=2.695mm D=2.685mm and so on... ..so G= 2.715 H= 2.725 W=2.735 J= 2.745 |
#106
N3ch!!!
spent the day at hollister yesterday playing with jetting. between 500-1000 above sea level, about 65 degrees. i've got 178 main, and i think 38 pilot, stock N1EF needle on the #1 clip. really like the way it runs as is, although there's nowhere for me to move the needle if i go above sea level or if it gets hot. also, i noticed a couple lean sounding clattery noises when doing half throttle plug chops.
so i started by raising the needle one notch at a time, just to see how it felt. about all that seemed to do was soften the transition into the powerband and make the throttle response more sluggish. it didn't get blubbery or load up down low, the half throttle rattle went away, and the plug got more chocolatey than tan. did that up to the 3rd clip, then put in the N3CH needle. N3CH is noticeably thicker than stock, and about a half a clip shorter in overall length. i started on the #3 position, right in the middle of things. and left it there. plug is tan on chops, there is no half throttle crackle anymore, low end seems a bit more healthy (seemed to be comfortable running a gear taller at low throttle settings and still had more throttle response from idle into the beginning of the powerband), feels like it maybe is pulling a bit less violently as it comes into the powerband. i really like the way it runs right now. it feels very healthy down low and very crisp across the board. mighty fun! there was some talk about idle and vacuum a few posts back, and i noticed that once the fatter needle was in there, my bike was idling faster. nothing else had been touched, aside from the needle being replaced. i ended up backing the idle screw out about a half turn, then playing around with that and the air screw to get it sort of in the ballpark. air screw is now two turns out, used to be one turn out. before, it would idle when cold, and then die off and become inconsistent when hot. seems to idle a bit better now, although i wasn't spendng much time focusing on that. didn't do any idle speed chops to see if i am rich or lean yet either. |
#107
Me too
Mine idled much higher as well. I am at 4-6000' mid 50's F.
I have the needle one clip down from the top, going to try second clip down today and see what the difference is I believe I am running a 40 Pilot and 180 main......I think |
#108
Steve |
#109
I noticed the bike will still idle even with the air screw wound right in now where it used to drown out in fuel. Been a while since I've done any plug chops. I have considered moving to a 172 main to get some more over rev but keep playing it safe with the 175. |
#110
This (my 180 main) might explain why the bike does not have the top end I thought it would.
Thread Tools | |
Display Modes | |
2010 250 EC Jetting. | enduro1 | Enduro Intake/Carburetion - 2 stroke | 13 | 08-19-2010 05:56 PM |
2010 Sachs fork factory compression stack specs(ec300) | bergerhag | Enduro Suspension | 9 | 07-01-2010 11:18 PM |
2010 EC250 Jetting | WTEC | Enduro Intake/Carburetion - 2 stroke | 1 | 03-26-2010 09:41 AM |
jetting for new 300 racing 2010 | fabulous furry | Enduro Intake/Carburetion - 2 stroke | 9 | 08-11-2009 09:28 AM |
04 EC300 jetting? | DWreck | Enduro Intake/Carburetion - 2 stroke | 13 | 11-26-2006 08:12 PM |
