Old 03-01-2013, 09:29 PM
Gibby Gibby is offline
2013 gas gas xc 300r South Alabama, Hot, Humid, Sea level
main 172
pilot 40
airscrew 1.5
top clip stock needle
golden spectro 44 to 1 93 octane, 100% no corn fuel.
I mainly ride tight single track, TECHNICAL woods, roots and sand
I am 6ft
200lb
intermediate rider,
Bike feels crisp with these settings, took a minute to get it lean enough,
Now just minimal spooge and rips all the way through the power curve.
suspension still working me felt reel stiff and divey in the front when stock,
This is were I am at now: I have adjust forks pfp 1.25 from full out, compression 14 from full in, rebound 16 from full in. rear shock backed off on spring 1.75 turns, rebound 20 out from in, compression 16 out from in, starting too feel a little better then it did stock though, only 10 hours so far I am still trying to dial it in!
13 gas gas xc 300r
02 drz 400 s love this thig to get to work
97 ktm 250 sx needs love but awesome
99 ktm 300 mxc sold
97 ktm 300 exc sold
89 ktm 250 exc sold
lots of other crazy.
Old 03-15-2013, 08:49 PM
n_green n_green is offline
Bike year & model = 2011 EC300E fitted with 36mm x 39mm oval bore modified Keihin PWK ASII carb and reed block spacer and fitted with modified head (squish - 1.28mm, compression ratio - 12.7:1)
Temperature (degC) = 20-25 degC,
65% - 80% humidity
Elevation (feet) = 1000f, or 100 - 300m.
Main jet = 180
Pilot jet = 42
Needle & notch =N3CH #3
Air screw setting = 1 turn out
Throttle valve/slide = 6.5 notched
Results:
Great torquey power which will happily lug just at idle all day and then respond crisply when required. Nice meaty (read fun) hit of mid-range power which builds and explodes into a screaming top end. With the 180 main and needle in clip 3 it was slightly rich throughout the needle/main jet circuits so smoothed the hit somewhat. This came at the expense of fuel economy: 5.2l fuel used for 35k's = 14.8l per 100k's.
I swapped to a 178 main and needle in clip 2. The awesome torque is still there but it now has a ridiculous hit into the mid and top end. Its fun and would be a good MX setup, but it is really hard work through tight trails. Better fuel economy but still not as good as I'd hoped. Used 2.9l for 23k's = 12.6l per 100k's.
I think I'll move up to a W diameter needle, the modded carb seems to like a leaner diameter compared to the std 36mm.
Old 03-18-2013, 10:36 AM
hamilton's Avatar
hamilton hamilton is offline
Default 2012 xc 200
Bike year & model = 2012 XC 200
Temperature (degF) = 40F
Elevation (feet) = Sea level
Main jet = 172
Pilot jet = 45
Needle & notch = NOZH 2 from top
Air screw setting = 3/4- 1 turns out
Pre-mix 40:1
Results:
No engine mods, AS 1 Carb. This setting works very well for me fine tune with air screw for best off idle power.
Old 03-19-2013, 06:49 PM
Temperature (degC) = 15-20 degC,
55% - 75% humidity
Elevation (feet) = 3000f, or 1100m.
Main jet = 175
Pilot jet = 45
Needle & notch =JD Red #2
Air screw setting = 1.5 turns out
Results:
Great torquey power which will happily lug just at idle all day and then respond crisply when required. Nice meaty hit of mid-range power which builds and revs nicely into a smooth top end. This needle is a good single track needle as it is really smooth throughout the range with no abrupt buildups of power. Fun can be had at the flick of the clutch however.
Used 5l for 50k's = 10l per 100k's.
Old 04-26-2013, 08:11 PM
theexception_03 theexception_03 is offline
2004 EC 250
Sea level to 1000ft
Dry climate
NEDW #2
175 main
40 pilot
A/S 2
Pulls hard in every gear, very strong 1/2 to wot, never fouls the plug even when riding slow in the tight stuff
no flat spots or bogging, best setting I have every had
Old 04-27-2013, 01:05 AM
adv rider's Avatar
adv rider adv rider is offline
Default 2011 xc250 wa state
38mm AS 2
n3cw #2 w/ shim
42p
180m
8.7 float height
air screw 1-2 turns depending
2012 xc300 - Great bike! sold looking for 18+
Old 04-27-2013, 02:18 AM
Simmo737's Avatar
Simmo737 Simmo737 is offline
Bike year & model = 2013 EC300R with the new cylinder arrangement 38mm AS2 east coast australia 98 fuel.
Temperature (degC) = 10 to 30 tested at 24
Elevation (feet) = 0 to 3000' (tested at 500)
Main jet = 178
Pilot jet = 42
Needle & notch = N3CJ 3 from top
Throttle valve/slide = 7
Pre-mix 40:1 maxima k2
Results:
Great all round jetting thanks to jakobi. 3.7 litres for 42.5 km on speedo, 37 km on GPS. Mainly tight single line single track ( cessnock rut fest)
Oz
Current. 2015 ec300r estart, 98 RM 125
2013 Ec300r 2011 Ec300e 2009 Husky TE310
1982 XR500 Honda 1981 KE100 Kawasaki
1978 GT80 Yamaha
Old 04-27-2013, 03:38 AM
Jiikoo811 Jiikoo811 is offline
Bike year & model = 2008 300 EC
Temperature (degF) = 5-25 'C (no idea what is 'F values)
Elevation (feet) = sealevel
Main jet = 180
Pilot jet = 45
Needle & notch = stock needle, one pos. leaner than middle pos.
Air screw setting = 1 round open
Throttle valve/slide = stock #7
Doma pipe and bigger PV-cover.
S3 high comp. head.. squish 1,15mm
Run clean and crispy, idling well. Idle start pinging if opened air screw more...quite cold weather still here Finland +5'C.
plated 300EC 2008
Old 04-28-2013, 09:24 AM
bally123 bally123 is offline
Bike year & model = 2005 250 EC
Elevation (feet) = sealevel + 1000ft
Main jet = 180
Pilot jet = 42
Needle & notch = DDK - 3.
Air screw setting = 2.25
Way way way better than std NE1f, Crisp and strong throughout. Fuel economy is excellent - way better than it was. A really good and cheap improvement (about ?6 + postage for the needle)
(Tried a 45 pilot but light throttle got sputtery and air screw was fully out - the 42 improved it.)
Was given and have just fitted a JD Blue ready to try next time out.....Thanks again go to Todd for this
Old 05-08-2013, 03:28 PM
55% - 75% humidity
Elevation (feet) = 300m.
Main jet = 178
Pilot jet = 42
Needle & notch =N3CW #2
Air screw setting = .75 turns out
Results:
Great torquey power which will happily lug just at idle all day and then respond crisply when required. Nice meaty hit of mid-range power which builds and revs nicely into a smooth top end. The transition into the mid-range is pretty abrupt and can make technical trails and hills interesting. This jetting was rich throughout the circuits once the needle got on the taper and it showed in the fuel economy.
Used 9.3l for 63k's =
Thread Tools
Display Modes
The jetting database needs your help! MattR General Discussions & Announcements 4 10-18-2017 05:34 PM
JD Jetting settings for linear power delivery? SpeedyManiac Enduro Intake/Carburetion - 2 stroke 5 04-06-2010 06:17 PM
Modification/Aftermarket Database SpeedyManiac Enduro Product Reviews 4 02-04-2009 07:09 AM
Jetting Database Announcement MattR General Discussions & Announcements 0 12-18-2008 08:58 PM
Jetting Database Summary MattR Enduro Intake/Carburetion - 2 stroke 0 12-18-2008 08:36 PM
