Riding Techniques & Training Increase Riding Skill, Physical and Mental Training, Weight Loss. |
#11
the first set of numbers (596) is the series and the 8 & 10 are the order they are listed in the Ohlins parts catalog.
Fred Overstreet 2010 EC250 SixDays 2004 GasGas EC300 -Sold to a good home 2006 GasGas EC250-Sold to a good home 2006 GasGas TXT 280 Pro |
#12
Whats the series number for the TTX spring?
#13
06310. & a 5.8 is 13 in the catalog -06310-13/58
#14
How about a 5.4? Rod was asking me.
#15
Should be a 06310-11/54 but I'm doing that from memory (58=13 56=12 54 should be 11)
#16
Yep, your spot on as i've recently found out.
#17
Did you end up sourcing one locally Rod?
#18
The rear shock spring on my bike has the number 00580 09/50 L235 (Ohlins / '06 EC200) Would I be correct in understanding this to indicate a 50Nm spring ?
I'm around 100kg / 220lb ready to ride, would a 52 or 54Nm spring be more appropriate ? The set up on this bike is a bit strange - there was only 7mm preload on the spring, yet the race sag is only 85mm with my weight on board. I double checked this several times because it looked 'wrong', but got the same results.
'00 Montesa Cota 315R '13 Husaberg TE 300 |
#19
Yes, the 06 200 has 50nm spring as std. I am about the same weight as you and use a 5.6 kg spring from Enduro Engineering. I use 0.45 kg springs in the forks.
Sent from my OMNIA7 using Board Express
Anders "So you know, that you're over the hill when your mind makes a promise that your body can't fill" (Little Feat: Old Folks Boogie) 2015 EC200 Racing: TE bars, Rekluse Core Exp 3.0, 38mm Lectron & Ohlins S3 steering damper 2006 EC200: 2011 plastics, Rekluse Z-Start, revalved KYB forks & Scotts steering damper 1998 Bimota Supermono 1986 Duc Mille S2 1975 Guzzi sidecar hack 1961 Morini Corsaro 125 etc |
#20
Thanks Anders, I thought it was too soft. I'll check the springs too because they do dive.
Thread Tools | |
Display Modes | |
Fork bleeders for Ohlin forks. | Porkyblader | Enduro Suspension | 1 | 11-15-2010 11:36 PM |
2003 EC 200 Ohlin rear spring | lankydoug | Enduro Suspension | 8 | 08-30-2010 04:35 PM |
