#11
So things are much better now. Still not one kick bike, but not 20 kicks either. With proper tdc positioning, it will start first or second kick now, when hot.
I cleaned out all electrical contacts, put new plug in and cleaned out carb. Pilot jet and main we're both not looking good. We also repositioned kicker bit higher. I really hope that's the extent of the problem. Thanks a lot for the tips!!! |
#12
But the ring were fooked lol
03 ec300 honda cr500 94 |
#13
Bike can backfire on second-third kick sometimes, but fire right up with a TDC positioning.
What's the reason for backfire? |
#14
I don't know about that in a 2stroke mate never looked in to it as it has never bothered me
#15
Make sure carb clamp is good and tight on the reed side. You could be sucking air.
Life is not a journey to the grave with the intention of arriving safely in a pretty and well preserved body, but rather to skid in broadside, thoroughly used up, totally worn out, and loudly proclaiming... "WOW! What an incredible ride!" |
#16
im sure it is. maybe to tight
#17
Update.
Replaced and cleaned entire pipe. Replaced airfilter. New plug with correct gap. Had first real ride today. 30+ miles only one issue. Will start separate thread on it. |
Thread Tools | |
Display Modes | |
GAS GAS 450 SM starting problem | adamos | Enduro Engine 4 stroke (including EFI & Exhaust) | 4 | 02-23-2012 03:21 AM |
Starting problem | SeanUK | General Discussions & Announcements | 2 | 06-25-2008 12:29 PM |
04 450fse Starting problem | gasser-downunder | Enduro Engine 4 stroke (including EFI & Exhaust) | 4 | 04-25-2007 05:54 PM |
03 400fse starting problem | smnl4l | Enduro Engine 4 stroke (including EFI & Exhaust) | 3 | 04-15-2007 10:20 PM |
starting problem | Dicko | Enduro Engine 4 stroke (including EFI & Exhaust) | 8 | 03-06-2007 04:16 PM |
