#11
So it sounds like a "yes".
Thanks to all. J
2015 KTM 450 XCW 2014 350 XCF Wife's 2009 200 ec. Loving it 2007 Beta Rev 3 270 2007 KTM 200 XC Wife's Public Lands belong to the Public |
#12
My riding buddy has an 08 ktm 200xc-w and i ride an 02 gas gas xc200 and i wouldn't trade him for the world (unless i could sell the ktm after the trade and buy another gas gas
#13
If you do not opt for the head mod a cheap solution is to use a thinner cylinder base gasket which will advance the port timing and bump compression. Advancing the timing will in enhance bottom end to.
Unless you ride it wide open all the time, a 38mm carb is too large for a small cc enduro engine. I put a 35mm carb on a EC125 and a MC125 in place of the 38mm that came stock. With the smaller carbs they jet easier and run much cleaner/better at low rpm. |
#14
My 02 had 2 gaskets std I removed one which reduces the open duration making the ports open later so I wouldn't call that advanced. But the head mod is still required. If you get the squish close enough so it is working, the comm will be too high so it does need machining of the dome as well as a healthy skim.
'07 EC300 GG '14 TXT250 GG '? 496 CPI Cheetah RZ/RGV hybrid '22 765 Street Triple RS '21 XTrainer '69 Stinger T125 Suzuki '23 TRS 250RR (it's a Trials thing) |
#15
I found this. http://polariswatercraft.com.au/basi...roketuning.htm In general, if a tuner wants to adjust the engine's power band for more low to mid range he would do the following things. Turn down the cylinder base on a lathe to increase the effective stroke (distance from TDC to exhaust port opening). This also retards the exhaust port timing and shortens the duration and increases the compression ratio.....
#16
Several good suggestions here already but I will add one that always works - gear lower. If you don't ride faster than 50mph I would suggest 12/50 gearing on a 200. 13/54 would be close to 12/50 but would take a longer than stock chain. Yes a 12 tooth cs will wear a tad bit faster but the wear difference is little enough to be a non-factor. Chain slider will wear a lot faster (with a 12 cs) if you run a loose chain.
#17
Smartest thing said yet Gasser.
Z, yes retard is closer to correct. But they aren't really using a good description of what happens in a running engine. Not that it matters, and I'm starting to sound like a dick.
#18
![]() Quote:
![]() ![]() 12/50, okay thanks for the tip! It appears I will be buying a 09' 200 with less than 30 hrs on it. It has the stock pipe. Guessing these will be my mods for more low-end (if needed) in approximate order: Ensure Jetting is correct/best for low-end PV cover. -put one on my 10' 300 and liked what it did Gearing 12/50 I guess. Maybe even lower? Reed or Pipe spacer ....maybe ? Flywheel Weight Squish Does the 09' have the rain/sunshine switch? Happy New Year! J
#19
Also, make sure the power valve is correctly adjusted. I'd actually do this and check the squish measurement/have the head machined, before you start doing anything else.
2011 Gasgas EC200, 1966 BSA 350 scrambles, 1972 Montesa cota 247 |
#20
...and maybe check piston and ring for wear
Thread Tools | |
Display Modes | |
does anyone make a big bore kit? | seamonster | Enduro Engine - 2 stroke | 9 | 01-21-2012 09:05 PM |
The Pro's Make It Look So Easy | Rick | Pictures & Videos | 1 | 12-04-2011 10:49 PM |
How to make gaskets | Rabbitist | Enduro Engine - 2 stroke | 5 | 09-17-2011 07:46 PM |
Do they make FMF SST | gasser250sm | Enduro Engine - 2 stroke | 1 | 12-26-2008 10:16 AM |
If we make it... would you buy it? | Steve@Motowest | GasGas Member Polls | 12 | 07-09-2008 01:15 AM |
