#11
Owned a 2002 YZ250 since new with countless hours and only replaced a top end and clutch...bike is bullet proof. Never lost a bolt
Bought a new Gas Gas 2014 300 and have rebuilt the water pump assembly twice, replaced two clutch MC's, along with other odds and ends, and have several bolts fall off. One leak was so bad I couldn't get the oil/coolant to drain after it mixed and had to take everything apart and clean with kerosene. Been a joy. |
#12
Also the dealer found out from Gas Gas that the MC was a known common failure, but once I was out of my 30 day warranty, the cost of the fix was on me. That sucked especially for a known factory issue. It is an awesome bike but not the end all be all. Nothing against Gas Gas, the 300 is one killer machine. Only time will tell (if I keep it that long). |
#14
I remember hearing about a run of the AJP units that were "bad" so to speak. I believe this was when AJP was changing hands?
#18
I put a Magura on mine. Way better than the AJP.
#19
We need to be careful about "blanket statements" because they can mislead people we do not wish to mislead. There is simply no way that a Magura mc can be "way" better than a "good" AJP mc. Only way it could be noticeably better is if it pulled the clutch lever for you. It could very well be that AJP had a bad production run as another member here suggested and may still be having problems but for years they made excellent clutch master cylinders. I just don't want new members here to worry about their clutch mc if they have an older bike.
#20
I switched my 12' Magura with the AJP off of my 97', the AJP pull is smooth and consistent. The Magura was either on or off feeling, lacked the modulation I could achieve with the AJP. My vote would be for the AJP hands down.
BTW the AJP I'm using is near 20 years old. I've owned it for almost 10 of those years and never had to once rebuild or fix anything on it. Still has the original lever. |
Thread Tools | |
Display Modes | |
does anyone make a big bore kit? | seamonster | Enduro Engine - 2 stroke | 9 | 01-21-2012 09:05 PM |
The Pro's Make It Look So Easy | Rick | Pictures & Videos | 1 | 12-04-2011 10:49 PM |
I banned some users by mistake... | webmaster | General Discussions & Announcements | 4 | 02-07-2010 09:52 PM |
Do they make FMF SST | gasser250sm | Enduro Engine - 2 stroke | 1 | 12-26-2008 10:16 AM |
If we make it... would you buy it? | Steve@Motowest | GasGas Member Polls | 12 | 07-09-2008 01:15 AM |
