Old 10-01-2017, 12:14 PM
Zman's Avatar
Zman Zman is offline
I would agree you should probably keep the cranks and weights together as from the GG factory.
Old 10-01-2017, 01:40 PM
70455gto 70455gto is offline
Thanks zman. Swapping cranks now. Keeping weights paired with respective cranks.
Old 10-02-2017, 10:41 AM
slocalspode's Avatar
slocalspode slocalspode is offline
Does the '99 engine still have the counter balancer installed?
I am guessing the different weights on the cranks is because of this.
The '02 motor does not have the balancer.
I would check into this swap further before continuing.
You might try and private message Jim Cook, he used to own Smackover
motorsports and is a guru on GG bikes.
Old 10-03-2017, 06:35 PM
99 motor was bottom end only with few clutch side parts.
Both cases look identical (02 and 99). How can one identify counterbalanced vs not motor?
Evenweight = counterbalanced and uneven weight= not counterbalanced?
If I get it wrong, it vibrates like holy heck?
Old 10-03-2017, 07:34 PM
[IMG]99 ec250 and 02 xc250 gasgas crank weight by S NELSON, on Flickr[/IMG]
Old 10-03-2017, 07:41 PM
[IMG]99 and 02 gasgas cases by S NELSON, on Flickr[/IMG]
Old 10-04-2017, 06:35 AM
Zman's Avatar
I thought GG ended the counterbalance in 1998.
Old 10-04-2017, 10:34 AM
Here is a picture of my 98 motor with the balancer shaft.
above and to the right of the stator.It is possible that the enduro
bikes stopped using the balancer in 99. I thought it was 2000.
I think the quad bike motors used the balancer for several more years.
Old 10-04-2017, 11:07 AM
Thanks slocalspode! Do you have partial or full weight installed behind crank nut and gear on clutch side of crank?
Old 10-04-2017, 11:38 AM
Zman's Avatar
That is the magnetic flywheel that corresponds to the Ducati stator coil in the metal ignition cover. It serves dual purpose as a flywheel weight.
My 2000 does not have a counter balancer.
Tags
bearing, crank, radial, spins
Thread Tools
Display Modes
Crank bearing failure .WTF ? Getoviq95 Enduro Engine - 2 stroke 2 04-16-2017 01:27 AM
Crank Remover and Crank Installer tools for EC250 Fabry Enduro Engine - 2 stroke 5 06-25-2013 07:24 PM
Crank bearing help please!!!!!!! Porkyblader Enduro Engine - 2 stroke 2 09-09-2011 04:46 PM
07 Crank bearing... NEED URGENT HELP. wence Enduro Engine - 2 stroke 11 05-23-2010 02:25 PM
2007 EC250 Crank Bearing? BIG TOOL Enduro Engine - 2 stroke 9 11-23-2007 02:47 AM
