Old 08-06-2018, 01:17 PM
Mcurtis25 Mcurtis25 is offline
No I haven?t, I?ll go do that right now and see what turns up
Old 08-06-2018, 02:31 PM
Just pulled the main drain plug, that case oil is pretty transparent and thin compared to what a typical oil Change would be
Old 08-06-2018, 03:21 PM
Pull the crank case drain plug underneath the crank case. You will be looking to see if any coolant drains out. This will tell you if you have a crack or leak at one of the coolant passages where it intersects the case, cylinder, or head.
Old 08-06-2018, 06:31 PM
cbutler's Avatar
cbutler cbutler is offline
Yep that is what I was pointing to. If the oil is not milky there is no water in it.
02 EC 200
03 MC 250
88 VT 800
01 TXT 280
Old 08-06-2018, 07:47 PM
There was dark oil that smelled like case oil came from the crank drain plug
Old 08-06-2018, 10:26 PM
You need to replace the right side crank seal.
Old 08-06-2018, 10:42 PM
Good video on how to replace the right hand seal without splitting the cases.
I would check the bearing carefully to make sure it is not failing, which could possibly cause the seal to leak..
http://www.youtube.com/watch?v=w_Ms5C5TOLw
Old 08-06-2018, 10:58 PM
Awesome thanks! I was looking for a video of some kind lol I?ll check it out!
Old 08-07-2018, 07:33 AM
Zman's Avatar
Zman Zman is offline
While that may fix the one problem he still has the coolant problem which is likely either a warped head, bad casting or bad gasket.
When you changed the bottom base gasket, how thick was the gasket? The GG kits come with a paper shim gasket that is very thin and is a spacer that gets used with another gasket because it is not intended to be used by itself.
Old 08-07-2018, 08:13 AM
When I got down to it there was just one gasket on, the larger main one, but I had ordered the paper as well so placed it on top of the bigger one when I was re assembling.
Tags
bog down, ec300, smoking
Thread Tools
Display Modes
Kx 85 problems welsh.Z.S. Enduro Engine - 2 stroke 6 05-16-2017 03:31 PM
Engine overheating and smoking a lot ? poelinca Enduro Engine - 2 stroke 36 06-08-2016 01:42 PM
2013 started smoking bulbs... rgranger Enduro Electrical & Wiring 16 04-10-2013 08:08 AM
yard sale! smoking cheap prices! jt633 Parts 7 04-04-2013 08:22 AM
