#11
I'd be thinking more like a 40 pilot.
#12
Yup. I gotta call Les one of these days though. I gotta believe he knew what he was doing when he wrote 48 and middle clip but I just can't make sense of it (or get it to work) with my limited knowledge.
#13
I just got the LTR jetting kit, so I'll be testing it this spring.
Granted mine is a 250, but I hope I don't have some of the pilot "oddities" that some of the 300 guys seem to. |
#14
Eff is right Brain VT. Run with a 40 pilot and you will see the difference. I have the LTR kit for my 250 but I only ended up using the slide because the rest was way too rich and my bike just bogged around. I'm running with a 35 pilot, #0 slide Mid Clip and a 175 main in all temps with no issues. Seems to run better in the colder temps. I started at stock and got to my current setting so don't use mine as a starting guide (don't need to be fixing more than my own bike!).
#15
Have just returned from the my trip to the U.S.A and while I was in the area I paid Les a visit to get a jetting kit and powervalve cover for my 07 ec 300. Les is a wonderful person and only to happy to have me pick the kit up from him. From new my bike ran pretty ordinary down low and I was interested to see what difference the LTR kit would make. On my return to Australia I pulled the carb off and was puzzled to see a 178 N1EF needle 3rd clip and 40 pilot, As the LTR kit had the needle 178 main and 50 pilot Les also included a 45 pilot because of the splutter down low. This had me puzzled as it looked to me that it could only make my problem worse, but I had faith and installed everything including replacing the 40 with the 45 pilot. I took the bike for a run and all I can say is it was a different bike pulled clean right off the bottom, I pulled the plug and it was sooo! much better looking. I am puzzled as to how the kit fixed the bike and can only put it down to the needle design. I feel I could maybe go back to the 40 pilot but don't know if I should play with what seems close to perfect. Now for that powervalve cover Andrew.
#16
I installed the LTR kit on my 05 MC250 without ever trying to jet with stock needle.Stock pilot was a 40, and LTR kit came with a 48. By going to a fatter needle, it is possible to go up on the pilot jet, so I didn't question the huge jump The 48 smoked and blubbered all over the place at about 1200 ft, 60 degrees F. I installed a 42 and adjusted screw to 1/2 turn. Could have stayed with the 40. I already had the clip at the top of the needle. Ran great, but had a lean spot about 3/4 throttle. I took needles out and checked with Digital caliper. LTR has same top diam as stock, so pilots will run the same. LTR is straight taper needle, where stock is dual taper. All power valve bikes I know of run dual. Don't know why or how they determine where the tapers should be, or how someone decides a dual taper bike needs a straight taper. Four strokes like multi taper. I'll try both, and decide on my own I'm going to put my stock needle back in on the 2nd clip from the top and see how it runs. I may even go back to a 40 pilot. Air screw should adjust between 1 and 2 turns, or somewhere close. Don't believe in jet kits, the bike and carb manufacturers should know how to get top power out of their bikes. Bikes that don't run well, don't sell.
05 GG MC250- street titled 95 Honda CR500- ported with bigger carb 81 Yam XS650- restored from rusted yard ornament - - - - - - - - - - "Old" bikes> 06 KTM 300XCW- returned-dealer scam- 1st owner seized & returned prior to sale to me as "new" 87 Yam YZ490 81 Yam IT250 84 Honda v45 Magna 74 Suzuki TS400 76 CZ motocross 250-bought new in 81-should have kept 74 Kawasaki G5100 |
#17
Actually the N1E series are triple taper needles. I was told the reason for using these needles, with a sharp third taper, is because smaller mains are required. Main jets are available in finer increments as they get smaller, giving greater tuning flexibility. If you ride on the main a lot like in MX, no problem. I like the way the midrange feels with the single taper needles.
You have a different head, and maybe a different slide than the EC. Many variables. For measuring needles, no way you can get accurate #s on anything but the straight dia. with a digital caliper alone. I've played around with an optical comparitor at work, thats a cool toy. |
#18
needles
Three tapers? When I get home, I'll have to look again. I could only detect two, but I was using crude measuring tools. I just wish I could find info on manufacturers numbers.
I measured about a 3 degree taper on the stock needles last 15mm, which would richen up the part I suspect to be lean. I have a #7 slide. From what dealers have told me, the motors are almost identical, except for pipe, head, and flywheel weight(also opposite crank weight). With a digital caliper, I figured out the LTR letters for my 250. The diam is easy, the other two are interpolated by knowing the value of the variable letters. L1 has to be measured very carefully, or a X could get mixed up with a Y. A basic working trig knowledge can find the angle, you measure the diams and distance at two taper points, and treat it like two stacked right triangles, and calculate one angle using inv sine and multiply by two and hope it comes close to an angle that has a letter assigned to it.
#19
Let us know because it caused me no end of head scratching. When I finally abandoned trying to be anywhere near the LTR recommendations I settled on 35 pilot + 2nd clip for my EC300. Somewhat different eh? I also found the standard EF needle on 2nd clip gives a smoother transition.
Thread Tools | |
Display Modes | |
where to go from here. jetting q. | dank | Enduro Intake/Carburetion - 2 stroke | 105 | 04-11-2011 04:25 PM |
LTR or JD Jetting Kit | Elvis74 | Enduro Intake/Carburetion - 2 stroke | 7 | 04-08-2010 02:49 PM |
Need help jetting an 06 EC 250 | piperpilot12w | Enduro Intake/Carburetion - 2 stroke | 3 | 11-16-2008 11:19 PM |
jetting help for 05 300 please... | mackmack | Enduro Intake/Carburetion - 2 stroke | 5 | 09-03-2007 05:10 PM |
06 300 jetting | fury1 | Enduro Intake/Carburetion - 2 stroke | 1 | 07-31-2007 06:37 AM |
