Archive of For Sale Forum Old Common For Sale Forum (Temporary) |
2000 200/250/300 parts
here's an updated price list: parts on this list are available now.
these prices include shipping to the USA . international is more. 2000 excel front wheel (no rotor) $125 front brake master+lever+stainless line $50 rear brake master+reservoir $40 rear caliper+carrier+stainless line-brembo - will fit all models - may need spacer washer for newer models (i will include if needed) $70 swingarm (new bearings with 8 hours on them) $75 swingarm pivot bolt (new nut) $25 122mm ltr links $50 cdi (200cc) works nice for all models - not dual map. $100 ignition coil $30 Seat (99) blue factory cover, in excellent condition. will not fit 00 or newer. $50 seat (00) has been recovered - cover has tear or ten. foam is decent. this is the 'lower/wider' seat $40 complete clutch modified for cr250 plates, with new cush, basket drilled for oil flow.. complete with milled spacer, hub/basket/nut/plates (newish). everything you need. never squawked. $100 clutch master/slave/lever - rubber boot in master pluger is loose, but this works fine. rebuilt 1 year ago. $50 WER damper + mount $125 gnarly pipe no guard (from an 07 300) - has big dings $75 gas tank (04 i believe - has the recessed trials type cap- not the one pictured!) $65 aluminum subframe (needs welding - has repairs) $40 ALSO AVAILABLE: 99 forks (right side ups) $125 99 triple tree (right side ups) $50 99 300 bottom end (doesn't shift - haven't investigated) $200. no ignition. various yellow plastics - some in excellent condition .40 wp springs (i think..) - for under 160lb rider... i cannot remember rate, but i know they were too light for me. $40
07 ec300 was 00 xc200 now a 00 xc300. now parting out. 99 ec300 (now a pile of parts which are for sale) Stainless Cycle - Motorcycle Bolt Kits www.stainlesscycle.com Last edited by stainlesscycle; 03-27-2013 at 06:31 AM. |
i will take the clutch master, slave, and lever for $50. what about the rear brake pedal, i really need one of those. and how do i pay for the stuff.
pm sent...
07 ec300 was 00 xc200 now a 00 xc300. now parting out. 99 ec300 (now a pile of parts which are for sale) Stainless Cycle - Motorcycle Bolt Kits www.stainlesscycle.com |
Wheres the 2k2?
I was waiting for you to say.. On my 07 I'm just stirring!
clutch basket
Does it use all CR internals and if so what year models
I have a rekluse for a Honda 2000 CR 250 and would like to know if that will work in a 2003 300
03-300 11-300 six days |
No time this weekend for the GG/KTM 2K-2 comparison. Hopefully next weekend. I will do a write up in another thread with pics as not to hijack this one anymore.
cr frictions and steels. i do not know if rekluse 2000 cr250 will work - it should aside from unknown throwout bearing spacing - don't know the differences between it and cr250. the easiest way is to try - you will need to grind the basket spacer washer - there's a thread somewhere with the dimensions.
tank
i will take the tank. pm me
Thread Tools | |
Display Modes | |
2000 ec 250 | Rabbitist | Enduro Suspension | 3 | 09-15-2011 09:13 PM |
