#21
I think it is more piece of mind for me. Bests the ol' tap the kill switch routine.
I exchanged emails with Troffer88. He highly recommends the longer throttle cable. |
#22
Yes to the longer cable.
Motion Pro T3 -- Roughly $38 This is the one http://www.cyclebuy.com/shopping/mot...m#Larger_Image
2012 - XC 300 Racing Seattle, WA |
#23
I highly recommend the Motionpro T3 cable, for peace of mind Sure beats having to safety wire the normal cable at both ends. Just thread em on and snug down the locnut.
#24
The consensus is the Kelly-modded metering rod with the stock-length power jet, and the Motion Pro T-3 throttle cable (get that when I order?).
Remote choke: si' o no? I take it the Keihin choke assembly is not compatible? From whom should I order the Lectron? MotorSportz or Lectron? Neither one is being particularly courting of me. I kind of like to be wooooed some. Edit: What's this "Power Ring" thing? http://www.lectronfuelsystems.com/products/parts-1.html |
#25
AzRickD I will ask Kelly to blow in you ear
#26
That would be so sweet of him.
#27
With my Lectron I had to remove the locking cable nuts at both ends in order to get the carb slide to go all the way down. How bout you Jake or Tim? Which is no big deal but curious if you did as well?
#28
I worked with Kevin @ lectron when I ordered mine.....Kevin went out of his way to make it work.....several shipments to and from......but just couldn't get it right.......
Hind site......i should have kept the crab for my EC 200. My delemi was the lectron was too long, would not fit on my Yamaha 125.
Rick 99 EC 200 06 RM 250 AMA D36 375X OTHG 375S ***Thanks for the support : Twin Air /O'Neil Racing / Race 100% / Matrix Concepts / ODI / Mika Metals |
#29
I couldn't get the T3 to work with the adapter I got with the Lectron so went back to a normal motion pro 2.5" longer gas gas throttle cable. I was advised after though that adapters were available for the threaded cables.
#30
You can make the stock cable work, I have a under bar damper so it made it even worse. I just didn't like it being as tight as it was, seemed like a stuck throttle just waiting to happen with the carb end safety wired in . The Motion Pro cable Lectron sells was perfect .
Thread Tools | |
Display Modes | |
Lectron Carb | singletracker | Enduro Product Reviews | 145 | 07-27-2013 12:20 AM |
Smart carb my review | Diggs345 | Enduro Product Reviews | 9 | 11-28-2012 03:28 PM |
RB-Designs carb mod or PowerNow? | AZRickD | Enduro Intake/Carburetion - 2 stroke | 14 | 01-23-2009 05:50 PM |
RB Designs Carb Mod | Magellan | Enduro Product Reviews | 18 | 06-11-2008 01:44 PM |
RB Designs Carb Mod? | Boomhauer | Enduro Intake/Carburetion - 2 stroke | 4 | 03-20-2007 03:09 PM |
