#21
yes,a critical lesson and its never initially instinctive to do.feet tend to start paddling in the air all by themselves,then ass shaped dents appear in dirt!
Not to be forgotten.ever.
2013 ec200r |
#22
Automotive engines used 160* thermostats for many years. It was common to install a 180* thermostat in the winter to increase heat output from the heater.
Using increased engine temperature became important only for pollution control issues. Higher temperatures altered the formation of oxides and other harmful substances and helped the pollution control system perform better. As long as an engine is warm enough that the oil viscosity allows proper oil flow, the engine will be fine. A 2T can operate successfully at lower temperatures than a 4T.
2011 EC250E Last edited by Neil E.; 03-30-2016 at 03:40 PM. Reason: grammar |
#23
I'm still missing something. I have a clean carb (I just did it last weekend, and I am thorough), I have fresh gas, no ethanol, yet my bike will not run correctly until about 140. Of hundreds of engines of all kinds I've come across in my life, they all act in a similar matter
I don't think oil plays much a part of cars engine temperature. You can always use thinner oil. Back in the day of 160 thermostats, leaded gas, and carburetors, cars were lucky to make it 100 thousand miles, and required constant maintenance. Plus you had 10w oil, 20w oil, etc. With a 5w-30, you can cover a much larger temperature range. Now with 195 thermostats, and fuel injection, I have yet to see an engine honestly wear out. People blow them up, sure, but its always by abuse. I'm not sure why this turned into a thread about how 2 strokes run ice cold. The fact is engineers designed the engine to run at a certain temperature, and I guarantee it isn't 120F. It has little to do with oil, and everything to do with tolerances, especially the piston and cylinder. I will lay money you do more damage running an engine hard at 120F than at 240F. So with that, I will no longer respond to this thread unless its about thermostat housings. I'm simply too boneheaded to listen to more.
2006 GasGas EC 300 |
#24
I have a 2011 EC 300 with the original factory thermostat. I have a trail tech with the red temp warning light set for 200 degrees F. My bike seems to run in the 160 to 180 range. It only gets to 200 degrees if I'm stuck in some dense tight grown over single track at a crawling speed, but it never has boiled over.
I have some buddies that ride pumpkins and they boil over constantly. Maybe the heavier sandcast engine cases of the GG act as a heat sink?
2011 GG EC 300E, 1994 CR 250R, 1984 RM 250 E, 2022 Ranger 300 "If you stop eating donuts you will live 3 years longer. It's just 3 more years that you want a donut." ―Comedian Lewis Black "I think best when I have a wrench in my hands." Soichiro Honda "Dreams are messages from the deep." -Unknown Sardaukar |
#25
#26
Well clearly you'd decided to fit one before this thread started so go ahead, fit the hottest one you can find.
'07 EC300 GG '14 TXT250 GG '? 496 CPI Cheetah RZ/RGV hybrid '22 765 Street Triple RS '21 XTrainer '69 Stinger T125 Suzuki '23 TRS 250RR (it's a Trials thing) Last edited by (F5); 03-31-2016 at 03:42 AM. |
#27
Since i fitted a fan the bike will boil much quicker than without the fan purely from the restriction caused by the fan and the cowling (obviously this is if i forget to turn the fan on - with the fan on it never boils ... generally stalls on the next downhill because i forgot to turn it off!!)
#28
Yes I did, I was asking what the best method was. A thermo-bob has a bypass to keep coolant re-circulating while the thermostat was closed, where the stock gasgas thermostat simply blocks one line until its open.
#29
Best post ever .....
2011 EC250E |
#30
Here's my thoughts. The thermostat is just one more thing to go wrong. I think it came from a Euro emissions requirement (maybe not) and my gasser is the first bike I've ever owned to have one. I believe that when I melted down my engine, the thermostat was possibly at fault. I removed it and didn't notice any difference in how the bike ran. (After the repair obviously) In fact, it boiled over on me in exactly the same spot on the same trail, both before and after the t-stat. If the bike runs cooler without it, then great. I happy for the extra overhead.
2013 GasGas XC300E 2005 YZ290 1973 Honda CB175 1997 KX60 1983 Yami Tri-Zinger 1984 Suzuki Alt 50 1969 Trail 90 1971 Trail 90 1972 Trail 90 |
Thread Tools | |
Display Modes | |
Which radiator cap | VINTAGE RACEWEAR | Enduro Engine - 2 stroke | 3 | 01-19-2015 03:36 PM |
radiator? ?? | spooly | Enduro Engine - 2 stroke | 7 | 04-15-2014 10:25 AM |
radiator | wence | Enduro Engine - 2 stroke | 8 | 06-23-2013 02:17 AM |
Need a radiator | Silver | General Discussions & Announcements | 0 | 08-30-2010 04:48 AM |
