Old 05-19-2021, 08:35 PM
vtskier vtskier is offline
Check that the battery connections are tight. I had a loose battery connection and bike failed. I also had no spark when battery was disconnected completely.
Old 05-20-2021, 01:03 AM
Mikeyx Mikeyx is offline
No battery in this model.
Old 05-20-2021, 04:49 AM
Gasser Nate's Avatar
The source/exciter coil should put out at least 100 ac volts with a proper peak voltage adapter. The pick up/crank angle sensor between 4-10 volts.
Anything less on either will cause a weak/no spark situation.
Voltages are a much more reliable way to test.
Old 05-20-2021, 04:50 AM
Anders's Avatar
Anders Anders is online now
Originally Posted by Mikeyx View Post
Where are the ground points(s) located? Are there more that those next to the coil?
The ground conenctions that matter in this case, are the two screws that fixes the coil, and the point on the frame where they are fixed. This point on the frame has to be free of rust. And then we have the connection between the engine and the frame. Same thing there.
Anders
1998 Bimota Supermono
1986 Duc Mille S2
1975 Guzzi sidecar hack
1961 Morini Corsaro 125
etc
Old 05-20-2021, 11:08 AM
Would someone explain me the function of the 'stop' button.
I mean, does it short or disconnect a wire, and which wire?
Old 05-20-2021, 12:27 PM
Neil E. Neil E. is offline
It usually grounds out one of the CDI terminals. Wire color can vary by year.
2011 EC250E
Old 05-21-2021, 02:50 AM
I found reference values for resistances. Here's what I measured (having reset the multimeter down to zero), with the ref values in parentheses:
- Impulse coil: 114 ohm (80-120 ohm)
- Exciter coil: 17.2 ohm (10.2-15.2 ohm)
- Charge coil (yellow-earth): 0.72 ohm (0.54-0.80 ohm)
- Carge coil (white-yellow): 0.13 ohm ( 0.13-0.19 ohm)
Apparently, no 'defect' in the stator?
Is the plug wire supposed to have zero resistance?
Old 05-21-2021, 04:49 AM
What are the voltages? The exciter coil is out of range looking at those figures...
Old 05-21-2021, 05:25 AM
You mean voltages while kicking the start?
Old 05-21-2021, 06:11 AM
Anders's Avatar
Yes, I would say so.
Anders
1986 Duc Mille S2
etc
Thread Tools
Display Modes
Spark Plug 2011 EC300 iamovru Enduro Engine - 2 stroke 9 04-12-2014 09:26 AM
01 EC300 Spark Arrestor carlg Enduro Engine - 2 stroke 6 12-14-2009 07:59 PM
01 ec300 spark plug.... jhendr3702 Enduro Electrical & Wiring 1 07-02-2008 07:53 PM
