Old 03-05-2008, 07:56 PM
widebear's Avatar
widebear widebear is offline
Banned
Too dirty, love the smell though.
Thinking more of Maxima 927
Old 06-10-2008, 10:48 PM
stvbird stvbird is offline
Here is a question for the petro-savy guys out there. 100LL (LL=low lead) actually has a ton of lead as the ancient design of piston aircraft engines were never updated like their automotive counterparts, so what does that do over time, build up wise? Do you end up with lead build up in your powervalve, etc..??
Current Rides:
07 EC250 (Plated, best handling woods bike ever!)
07 525XCW (Plated, dirt and SM)
Previous rides:
05 KTM 300EXC, 02 Honda CBR954RR, 01 Ducati 750SS, 99 Suzuki RM250, 98 Kawasaki KX250, 95 Honda CR250R, 95 Suzuki DR350, 97 Yamaha 350 Warrior, 86 Suzuki DS125.
Old 07-04-2008, 11:06 PM
iajim iajim is offline
Default Av gas / Lead
The short answer is yes, you will end up with some lead on the powervalve, exhaust port, etc. As you're aware, some unburned gas will exit the exhaust before the piston closes off the port, this is where the lead comes from . I wouldn't lose any sleep over this, normal p.v. cleaning, using cleaning solvents, wearing some nitrile throw away rubber gloves should take care of any build up - lead, carbon, whatever. In the 1960's when muscle cars ruled everything, pump gasoline ran about 98 octane, to get this a refiner would use about 4 grams of T.E.L. -Tetra Ethyl Lead per gallon , it was readily available and it worked great with the naptha base material of gasoline. It also worked even better when other octane enhancers were added. Then the down - side , it was found to cause cancer,( pure T.E.L. 100% , not diluted in a gallon of gas) and the lead did cause pollution. The last year of leaded pump gas, the amount of lead was down to .1 or .2 grams per gallon. I don't know how much lead is currently used in AV gas, I would venture a guess that it is much less, but that is only a guess.
Thread Tools
Display Modes
E85 fuel fkmf6 General Discussions & Announcements 29 01-20-2014 10:18 AM
fuel/oil mix dareuk Enduro Engine - 2 stroke 16 05-09-2010 03:46 PM
Fuel tap fault Warwick Simpson Enduro Intake/Carburetion - 2 stroke 0 11-09-2008 12:15 AM
Fuel ? west aussie gas 450 Australia & New Zealand 9 07-01-2008 04:51 AM
Fuel range and fuel light sanderjavant Enduro Engine 4 stroke (including EFI & Exhaust) 6 01-05-2008 02:35 AM
