Old 11-01-2018, 04:58 AM
New stator has arrived! Next job to throw it in the bike!
Old 11-01-2018, 07:51 AM
Anders's Avatar
Anders Anders is offline
Did you go the KTM route?
Anders
1998 Bimota Supermono
1986 Duc Mille S2
1975 Guzzi sidecar hack
1961 Morini Corsaro 125
etc
Old 11-01-2018, 04:28 PM
Yep.. OEM pumpkin stator.. Still need to splice the harness and then get it on the backing plate.
Old 11-07-2018, 04:08 PM
BLD's Avatar
BLD BLD is offline
Sorry I missed this earlier. The splice part is pretty easy and mine has held up well through some nasty rides and falls... Too bad my keyswitch failed last ride in the sand. Had all electrical but the E-start button... Good luck with the sale, If I had the cash I?d be asking you how much, love my 13!
Edit: I am done caring why my apostrophes always turn to question marks!!!...
Old 11-25-2018, 11:52 PM
I finally pulled my finger out and spliced it up this morning. Pretty straight forward. Bit of measuring, bit of trimming here and there..
Ended up pretty tidy in the end. I went for butt crimps + heat shrink on the joins. Used some plastic sleeving over the stator end and through the grommet, and then a nice big length of 10mm heat shrink up the other end which I slide back over the existing plastic tubing while joining, and when completed went back over the old to the new and fitting all the joins within. Pulled up beautifully and just needed a few wraps of tape at each end to ensure it's sealed up.
Haven't got around to kicking it in the guts or taking any measurements yet.. I probably should though!
Old 11-26-2018, 12:50 AM
Well good and not so good..
12V is back. Regulator still seems to be misperforming on this bike.. Running around 12-13V on idle but not really trimming well at all. Headlight is working... Horn works.. But indicators, brake light, tail light all dead.
The loom has been hammered with lots of mud riding.
The indicator flasher unit is a brand new one. I assume it works. The indicators have been in a box. They should work too. I'll double check on a 12V source. The taillight switch was packed with mud, and I assume the taillight itself isn't much better.. plus some insulation has worn through and exposed wires where it passes through the rear fender.
I hate auto electrics!!
Old 11-26-2018, 12:35 PM
jpgibson's Avatar
jpgibson jpgibson is offline
Bronze Level Site Supporter
With my recent switch block debacle, one of the things I found was a bunch of earths ( which conglomerate on the loom about 10 cm from the headstock -towards the tail of the bike) had become disconnected from the main earth. All my lights were out. There are 4-6 from memory. My tail light was also gone ( and has only been on the bike a few months!
Good luck!
Old 11-26-2018, 04:12 PM
Cheers Jon. I had a quick probe across the indicator circuits front to rear and have continuity.. I'll do the same with the earth circuits.
Old 11-26-2018, 06:11 PM
(F5)'s Avatar
(F5) (F5) is online now
Aren't you selling it? I thought the approved method was to twist the wires together and then wrap it thoroughly with $1 shop insulation tape.
'07 EC300 GG
'14 TXT250 GG
'22 765 Street Triple RS
'21 XTrainer
'69 Stinger T125 Suzuki
Old 11-26-2018, 09:03 PM
I am mate.. But a few dollars for a neat job.. and happy next owner.. hopefully!
Thread Tools
Display Modes
Another KYB SSS Thread - 2013 EC250R Jakobi Enduro Suspension 135 03-29-2020 02:50 PM
Preowned 2013 EC250R Mo.man Used Bikes 1 04-10-2016 11:00 AM
2013 ec250r Jakobi Enduro Product Reviews 163 02-21-2016 03:52 AM
2013 EC250R - 130hrs Jakobi Enduro Engine - 2 stroke 24 12-17-2015 06:01 AM
2013 ec250r Jakobi Enduro Intake/Carburetion - 2 stroke 2 04-17-2014 08:08 PM
