#21
2011 GG EC 300E, 1994 CR 250R, 1984 RM 250 E, 2022 Ranger 300 "If you stop eating donuts you will live 3 years longer. It's just 3 more years that you want a donut." ―Comedian Lewis Black "I think best when I have a wrench in my hands." Soichiro Honda "Dreams are messages from the deep." -Unknown Sardaukar |
#22
Thanks. It's been a year and the bike is still working great. I did ruin that battery because I let it go completely dead over winter and it wouldn't charge back up but that was my fault haha.
-Mike 2009 Beta Evo 300 4T - 1982 Suzuki PE175 |
#23
I lost a battery the same way this past winter. It was on the old lady's honda reflex and I just forgot about it, lol, oh well no big deal.
#24
I don't have a white wire coming out of the stator on my 2005 EC 250. Do I need to rewind the stator to be able to wire in a DC reg/rectifier? I have the yellow, green, red, red/white, and black/red wires coming from my stator. It has a small 12v AC regulator mounted near the ignition coil as well. It is an American market bike as far as I can tell.
Trevor 007 Honda XR650R 05 Gas Gas EC 250 04 Sherco 2.9 trials bike 00 Aprilia Caponord ETV 1000 93 Kawasaki KLX 650 |
#25
ive put an e start on my old gasgas. How do avoid a frame earth when the starter motor is bolted to the engine. That is the earth!
I just need a small charging circuit, not bothered about lights ect |
#27
help??, still not having any joy
#28
As you have noticed, the starter motor uses a frame ground. Since you have an aftermarket FULLWAVE rectifier, you need to float the ground at the stator. This means that the stator frame ground has to be removed from the stator plate and connected to a new wire. So the rectifier input gets powered by the white wire and your new wire. This isolates the stator.
The rectifier output goes to the battery positive and battery negative. Battery negative is connected to frame ground so the starter motor functions. Keep in mind that your battery positive wiring to your switch gear should be fused for safety. Connect everything to DC so it is easier to understand the wiring.
2011 EC250E |
#29
For adding estart you should only need a simple hookup like this diagram:
2011 EC250E |
#30
I have attemped the original method that is in this thread but I am having an issue. THe power fluctuates horribly to the battery...fluttering lights, etc...Anyone else experience this?
Thread Tools | |
Display Modes | |
KTM front flip ground grab | noobi | Pictures & Videos | 4 | 06-20-2010 11:17 PM |
MY FSE 450 to SM conversion | cal_tony | Pictures & Videos | 11 | 02-05-2009 10:11 AM |
Anyone take their enduro bike to a trials ground? | stay_upright | Riding Techniques & Training | 0 | 12-11-2008 07:50 AM |
oversized floating rotor? | wheels7 | Enduro Chassis & Body | 3 | 02-21-2007 10:25 AM |
