Go Back   Rieju & GasGas Legacy Riders Club Forum > GasGas Enduro Technical Forums > Enduro Product Announcements
Enduro Product Announcements Announce new gasgas enduro products here - Vendors Welcome...
Old 07-01-2014, 01:03 AM
I truly tested my p3 on numerous rocks to the point where I had to replace the pipe because I could not get it to line up properly - this is the down side of CF guards the impact needs to go somewhere I suppose and the neck of my pipe was where the price was paid. The p3 is still on the new pipe (until I gather enough coins to get a propower )
If I could get dents blown out easily nearby for a decent price I might consider no guard but I have a tendancy to underestimate the width of my pipe so doubt it would work out cheaper
2003 txt250 Pro
2013 Ossa 280i
Old 07-01-2014, 06:21 AM
wence's Avatar
wence wence is offline
Bronze Level Site Supporter
As I have said before, after the endurox I fully expected my pipe to look the same as yours but not a dent at all.
The Propower are definitely tuff units.
I had a thinner prototype on my bike whilst doing the endurox and the new one is a much better and more refined unit.
I fully expect there to be no probs at all with dents and being thicker than the prototype it should resist bending the pipe a little more also.
Cheers Mark
P.S Nothing at all wrong with the original either , just upgraded to red
Xr 250 ( first bike)
98 Rmx
2007 Gas gas 300(swapped for trials bike)
2008 280 Raga replica
2012 Gas gas ec 300 E
Old 07-01-2014, 11:30 AM
StuJohnson's Avatar
StuJohnson StuJohnson is offline
Stu, looks like it might have been a bit more than a gentle lay down. I've never truly tested a P3 other than shielding from roost/trail trash and abrasions from gentle spills. Its always hard balancing the cost of protection vs the cost of a new pipe too.
I never said it was a gentle lay down.
2012 - XC 300 Racing
Seattle, WA
Old 07-01-2014, 04:36 PM
Nor did I
What I was saying is that regardless of what you bolt onto your pipe to protect it, there will be a certain force or impact that is beyond its ability. In your instance whatever you dumped it into, you did so with enough force to root the guard as well as the pipe, and I'd be surprised if anything else did a whole lot better. It may have made the pipe repairable vs a write off, but then again, its probably cheaper to just buy another pipe vs another carbon guard plus repairs. Ala, cost of protection vs replacement.
Old 07-01-2014, 05:14 PM
gasser's Avatar
gasser gasser is offline
I run a pipe guard and I also bent the head pipe to where it was nearly touching the frame. The pipe just barely covered the outer o-ring on the cylinder head and leaked badly. I bent the pipe back into shape by heating it with a mapp torch and using a large pipe stuffed into the end of the exhaust pipe for leverage. I could see that the head pipe needed to be bent back almost 1/2 inch so I measured from the edge of the head pipe to the other end of the exhaust pipe for reference then I kept bending till I got a measurement that was 1/2 inch shorter. Worked like a charm.
Old 07-02-2014, 04:29 AM
wence's Avatar
I did the same on this pipe and the previous.
I use a maddock/pick handle , which just fits the throat of the pipe and then bend and test till it is good and covers the orings etc.
Cheers Mark
98 Rmx
Old 07-02-2014, 05:58 AM
i did the same a few times and got pretty good at it, but i could not get the small bend away from the frame enough and also wheelieing onto rocks and landing on the guard bent that part up - short story is that i had a new pipe waiting on the bench so did not put in the effort that i would have needed if it was my only pipe.
am going to take the pipe to someone i know that uses water pressure to fix pipes, he seems to believe that enough internal pressure will bring the pipe back very close to the original shape
2003 txt250 Pro
2013 Ossa 280i
Old 04-22-2015, 04:15 PM
dalbertog dalbertog is offline
How about us 2010'ers. Don't forget to make guards for the 2010 EC250's that are out there. Please keep us posted, the RED guard is outstanding.
Old 04-22-2015, 10:16 PM
I believe the pipe shape is unchanged only the mounting points differ so the pipe guard will fit your 2010, but confirm with propower first :-)
2003 txt250 Pro
2013 Ossa 280i
Tags
carbon fiber, pipe guard
Thread Tools
Display Modes
P3 Carbon Fiber Appalachian Offroad Enduro Product Announcements 8 10-30-2013 01:01 PM
Carbon pipe guards are near... wence Enduro Engine - 2 stroke 3 09-07-2013 07:08 PM
P3 carbon pipe guard Skidad Enduro Product Announcements 80 03-20-2013 08:50 PM
Carbon Pipe Guard rootsnrocks Enduro Product Reviews 1 07-02-2012 03:29 PM
How best to remove carbon from PV components? d2w Enduro Engine - 2 stroke 9 02-21-2008 09:03 PM
