#61
What brand fork and shock oils were you comparing it too?
#62
One (or both) were Maxima.
#63
http://www.peterverdone.com/wiki/ind...spension_Fluid
Heres a good real life comparison re oil viscosities. Couldn't find any ratings on the Motorex Hydraulic Fluid 75 Mineral Oil, but at an average price of $15 for 100ml it would want to be the ducks.. |
#64
I paid $6.
There is no comprehensive list that links all the information (viscosity, additives, anti-foam, seal conditioners) into one handy table. |
#65
I have not had time to go back and read all your posts but I am very curious if you got the thinner steel that is the first one installed in the pack (part # 67.1)?
2012 - XC 300 Racing Seattle, WA |
#66
Yes, I have that doo-dad.
#67
I found some time to work on the Lectron (actually just fiddling with idle and a couple of twists to set the cable slack). After that, I opened up the clutch cover.
I was going to take the Rekluse Tech's advise and remove the X-rings to increase the clutch feel, but I decided just to replace three heavy blue springs for three new heavier gold springs. All adjusted up. Not a whole lot off difference off idle, except that it increased my free-play-gain enough that I could back out the adjustable slave cyliner one tic. This was all tested on the street. It rained a lot last night. I sure would like to go hit some trails this weekend. |
#68
I was going to take the Rekluse Tech's advise and remove the X-rings to increase the clutch feel, but I decided just to replace three heavy blue springs for three new heavier gold springs. All adjusted up. Not a whole lot off difference off idle, except that it increased my free-play-gain (about double) enough that I could back out the adjustable slave cyliner one tic. Did it slow off-idle engagement? Maybe a bit. No slippage detected at speed. This was all tested on the street. It rained a lot last night. I sure would like to go hit some trails this weekend. |
#69
I did a 33-mile rock-strewn ride with A and B riders. A few long, twisty, and technical hills gave me, the Gasser, the Rekluse, and the Lectron quite a test. I am very sore in the calves today. No getoffs or tip-overs for the day.
The Rekluse behaved exactly as I wanted it to. I was using the clutch lever when needed. I only had one bzzzt sound during the end of a particularly long climb. It lasted about the time it takes to say "bzzzt," and was no more. No overheating, by the way. |
#70
Sounds like a good run. Are you happy with the setup?
2011 GG EC 300E, 1994 CR 250R, 1984 RM 250 E, 2022 Ranger 300 "If you stop eating donuts you will live 3 years longer. It's just 3 more years that you want a donut." ―Comedian Lewis Black "I think best when I have a wrench in my hands." Soichiro Honda "Dreams are messages from the deep." -Unknown Sardaukar |
Thread Tools | |
Display Modes | |
RB Swab or RB Mod? 2005 to 2011 | AZRickD | Enduro Intake/Carburetion - 2 stroke | 23 | 07-23-2013 12:55 AM |
2005 to 2011 transformation questions | jcborden | Enduro Chassis & Body | 20 | 05-23-2013 11:05 AM |
2005 to 2011 transformation | whodat | Enduro Chassis & Body | 23 | 03-22-2013 10:30 PM |
2005 VS 2011 Shock | celler | Enduro Suspension | 2 | 03-03-2013 07:47 PM |
Why Upgrade from a 2005 to a 2011? | celler | General Discussions & Announcements | 36 | 10-18-2010 05:45 PM |
