Re-anodized fork service
Just tore down my forks for the first service since I had the uppers and damper rods T3 hard coated. To my pleasant surprise the oil was very clean, no sludge. This is after about 35 hrs which is a bit overdue I know. Just like a new fork. We will see how this holds up, I'll keep you posted on future services.
some guestions how many hours on the forks when you did this did it add size to the damper rod and if you dont mind roughly how much thanks glen
James 00 ktm exc 300 07 ec 300 |
Forks had over 100 hrs. Coating does not add any significant dia as its very thin, and before coating parts are etched or 'de-anodized" to bare aluminum. You could go a lot bigger on the damper rod OD without a problem as there is a lot of clearance between it and the bushing. The fork is more critical, but a strip and re-coat is no problem. The biggest concern before you spend your $$ is if the uppers are worn into the base metal. You can see the original anodizing worn off, but you need a good bore mic on an extension to measure it. If its more than a few thou deep forget it. I got lucky, mine was not too bad. The info is in the original post I did on this subject, do a search. Sorry I don't remember off hand. I think it was about $120 though.
Thread Tools | |
Display Modes | |
No service manuals - What a JOKE!! | mountainman | Enduro Engine 4 stroke (including EFI & Exhaust) | 14 | 10-10-2014 03:18 AM |
service manual | skid jackson | Enduro Engine - 2 stroke | 5 | 05-04-2008 08:11 PM |
06FSE450 Service interval | Eugene | Enduro Engine 4 stroke (including EFI & Exhaust) | 1 | 01-02-2007 04:46 PM |
Service Bulletins | MIKEWA | Suggestion Box | 2 | 11-28-2006 08:15 AM |
2003 pro 200 service dvd | Craig1413 | Other GasGas Bikes/Quads | 1 | 11-24-2006 05:29 AM |
