Old 09-19-2011, 11:58 AM
fire1998 fire1998 is offline
Default Raising oil level 2011 forks?
Need to bring my oil level from 130 to 110 in my 2011 zones. Anyone know what that would equal in cc's?
Thanks
Old 09-19-2011, 02:00 PM
I don't know the internal diameter (id) of your shocks but can tell you how to work it out
Vol=pi x id x h
So in cc that would be 3.14 x id (in cm) x 2cm
2003 txt250 Pro
2013 Ossa 280i
Old 09-19-2011, 03:02 PM
lankydoug lankydoug is offline
Les at LTR gave me that info for the 50mm Zokes on my Husky so I bet he could tell you what you need to know.
Old 09-19-2011, 03:49 PM
wasp4banger wasp4banger is offline
Vol=pi x id x h
Sorry to correct you Matt, but the above would give the area of the internal curved surface, pi x d gives the perimeter I'm afraid. (unfortunately for me, I'm a far better mathematician than rider!)
about 100cc per leg I reckon. The volume should be pi x id x id x h / 4, remember area is (pi x id^2) /4 or pi x ir^2.
Hope this helps.
Gas Gas EC 300 '06
BMW F650
Old 09-19-2011, 04:14 PM
thumperrider1 thumperrider1 is offline
I would just add 20cc at a time in each leg with a syringe via the bleed screw until it feels good and isn't bottoming out.
2018 XC300
Old 09-19-2011, 05:22 PM
I was thinking it was about 13cc equals about 10mm in oil level but I wouldn't swear to it.
Old 09-19-2011, 06:22 PM
2whlrcr 2whlrcr is offline
Geez, I guess I should have stayed awake in math class after all.
Old 09-19-2011, 09:51 PM
GMP's Avatar
GMP GMP is offline
You will also have to account for the volume of the inner tube wall and damper rod spring guide to be totally accurate in relating a volume to an oil level change as done on the bench.
Old 09-20-2011, 12:40 AM
Hope this helps.
You are 100% correct. I was going to sleep when I did it and this morning it struck me! Was hoping I could sneak back in and change it without anyone knowing lol
As for deducting spring and push rod, isn't the oil height measured with all of this removed? So all you need to do is to do the calc, get a cc syringe and add through the bleed hole
2003 txt250 Pro
2013 Ossa 280i
Old 09-20-2011, 01:59 AM
noobi's Avatar
noobi noobi is offline
I think its done with no spring, but everything else present. I just do it by volume. If you knew what the oil height and the volume of oil you put in was you could work out what the ratio of volume/height is.
Thread Tools
Display Modes
Anyone tried removing center bolt on lower triple clamp with sachs forks 2011? Simmo737 Enduro Suspension 12 09-14-2011 11:06 PM
2011 Sachs Forks - Tuner Info twowheels Enduro Suspension 7 06-17-2011 10:14 AM
EPA considering raising ethanol to 15% eff General Discussions & Announcements 17 06-01-2011 11:27 PM
Brent Martell : ISDE Fund Raising webmaster General Discussions & Announcements 7 05-31-2011 10:16 AM
GasGasRider.org T-shirts & fund raising coolum74 Suggestion Box 12 03-01-2009 02:41 AM
