Rear Brake Cooling Fins
I have a bad habit of riding my rear brake too much and it has been overheating. I'm trying to change my riding style, but I also added some cooling fins that seem to help delay rear brake fade. The fin is a really a single piece of 1/8" x 1.5" aluminum bent into a "U" shape and JB-Welded to the rear brake caliper. The JB Weld is a metalized epoxy and the heat conducts well across the glue joint. It definitely keeps the rear brake cooler.
Steve |
Rick 99 EC 200 06 RM 250 AMA D36 375X OTHG 375S ***Thanks for the support : Twin Air /O'Neil Racing / Race 100% / Matrix Concepts / ODI / Mika Metals |
Steve |
I epoxied on a small one inch by one inch heat sink from radio shack.. can get them for like 5-6 bucks glue it on just like you did with the u shape piece and you'll never overheat the brakes again..
Steve 16 Beta 350rr 04 KTM 525 sx/exc gone 03 KTM 625 sxc-rehab unit-did its job and now gone 03 GG 250 ec-gone 97 GG 250 ec Gone |
Solid rotor with organic pads, no problems even in south Jersey, with a lot of tail dragging around tight trees. Sintered pads conduct a lot of heat back to the caliper.
Steve |
I installed a DP 1601R rear brake rotor on my bike and the rear brake no longer overheats even with sintered pads. This rotor is from a KTM 950 Adventure and is much thicker than the stock Galfer rotor. It's heavier, but it really works! If you're having trouble with squeaking rear brakes that overheat, give this rotor a try.
Steve |
The GasGas factory solid rotor is very good if you can find one. The Moose solid for a KTM fits as well and is very thick. A good solid is all I need, they can keep all the waves, slots, and holes. I have a stack of take off Swiss cheese rotors.
Thread Tools | |
Display Modes | |
oil in cooling water | Klausen | Enduro Engine - 2 stroke | 10 | 08-06-2011 09:35 PM |
Rear brake position | Lildawg | Enduro Chassis & Body | 18 | 06-15-2011 11:17 PM |
FSE 450 rear brake... | Vinny | Enduro Chassis & Body | 4 | 06-09-2011 07:52 PM |
rear brake reservoir | oilman | Enduro Chassis & Body | 4 | 06-06-2011 12:10 PM |
cooling pump shaft | lufc | Enduro Engine - 2 stroke | 11 | 05-25-2007 05:42 PM |
