Best setup for ec300 2011 in hard enduro
Pretty new here and at GG family, just picks up ec 300 2011 riding in very tight woods, rocks...
After reading a lot of post, I see that the most common tip is to use higher gear and lug it... But in some place putting the 3rd or even the 2nd gear isnt fit to the specific area and the motor is run away without rotating the throttle. What is the best setup to smooth the power, and create linear motor? Jetting? reed spacer? Power valve? Currently running with everything stock, sea level, 20 degree Celsius Thanks. |
welcome to the site ... and the GG family!
for tight extreme riding i would suggest hyde skid plate and p3 exhaust guard, the revalve the suspension, you may find it a bit harsh if you ride lots of rocks, then what i have done to the gearing is i just dropped to a 12 front sproket, that gives me plenty low down in first for steep pull offs, but i find now that i do a lot of climbs in second enjoy
G2 throttle with the 400 cam.
Welcome DRN51,
Like Matt has stated in his post, recommend some guards. Maybe take a look at some type of protection for your hands if riding among trees. Bark Busters, Acerbis have a good selection. I also went with the Bonz mounts they fit nicely. I went with a larger sprocket on the rear and also find 1st gear not used much, but is still there if needed. You might find yourself coming up short on some fire roads but well worth the trade off. Maybe a pull strap. Suspension work I felt was needed on the 2010 but not sure about the 2011. Maybe someone else will add. Setting up your bike for your style of riding really is a personal quest and will vary wider amount riders.
HuskyDude 10 EC300XC 08 TE510 07 TXT 280 77 TY175 |
thanks forthe feedbacks guys!
of course I will pay attenation for the protection and guards, but what is most concern me is the linearity of the motor that i dont know how start to deal with this. |
I would say the pipe and silencer combo that comes stock on the 2011's is pretty linear to begin with. if you want it smoother the last thing you would want is to gear it down, but personally i geared it down two teeth in the rear- it works well for me. There are some silencers out there that will let it rev out a little quicker but it doesn't sound like thats what you want. Id ride it for a couple of events before changing anything up too much as practice is never as intense as racing.
Jetting 101! Have a look in the jetting section. Theres thread upon thread. First check to see if you have a 38mm carb or 36mm and then grab a few needles and start playing! These carbs are very sensitive to change and effect on power delivery.
ok thanks,can i have recomend basic jetting setup to start with him?
tecnichal ride, sea level, 20 degree Celsius |
First you need to determine whether you have a 36mm or 38mm carb. It is on top of the carb in a small round indention, from there jakobi will have you sorted.
Just my opinion here, but doesn't the new bike come with sea level jetting?
Thread Tools | |
Display Modes | |
Brentwood HARD Enduro- Day 2 | roughside | Pictures & Videos | 3 | 10-10-2011 02:54 PM |
Brentwood HARD Enduro- day 1 | roughside | Pictures & Videos | 4 | 10-02-2011 09:51 AM |
Brentwood Hard Enduro-- Special Test # 1 | Looki | Pictures & Videos | 11 | 09-03-2011 10:41 PM |
08 EC300 setup MX & Enduro | AdrenalineJunky | Enduro Suspension | 4 | 06-03-2010 09:41 AM |
The best light setup for an 07 Ec300??? | wence | Enduro Electrical & Wiring | 9 | 03-25-2009 08:42 AM |
