'12 Rear Suspension Linkage Bushing/Shaft/Axle
I took apart my rear suspension linkage to give the bearings a check and when I took the two bushings/shafts/axles out (of the frame and the rocker arm) I didn't pay close enough attention . They appear to be the same length and size but one is tappered at the ends and the other is not.
Which one goes where or does it matter? |
The tapered sleeve should go in the frame pivot because that uses the seals, so its a lead in taper. That said, you will be better off pulling the seals and replacing them with orings while you are in there.
Thanks Glenn. I knew I could count on you. I'm sourcing the orings now.
Everything was actually pretty well lubed in there which was a surprise to me from reading what others on the forum have found. |
Thread Tools | |
Display Modes | |
Linkage Bushing? | gasgasquebec | Enduro Suspension | 10 | 09-22-2012 11:41 AM |
Rear shock bushing | 2 strokes 4 life | Enduro Suspension | 1 | 01-30-2011 08:31 PM |
'06 EC300 Rear wheel "top-hat" bushing | Eugene | Enduro Chassis & Body | 1 | 01-23-2009 10:27 AM |
Zerks for rear linkage? | mike989 | Enduro Suspension | 7 | 06-17-2007 06:50 PM |
