Old 09-12-2007, 11:07 AM
brains's Avatar
brains brains is offline
Default Need help with cold start
Long story, but my 05 300 now has a 250 barrel and piston in it.
It will not kick start cold, jump start it down the driveway and it starts in half a meter.Once warm, no problem with kick starting, first kick.
Any ideas? I'm think carb problem?
Main 172
Low 40
clip 2nd from top
Old 09-12-2007, 03:37 PM
Harry's Avatar
Harry Harry is offline
For what its worth I have an 02 ec300 that has the same symptoms. I have only recently "learnt" how to start it when its cold.
1) Fuel on - choke on
2) Kick over slowly -twice DON'T touch the throttle
3) Give it a good boot - still no throttle
It lives!
hope this helps (Ex Mooi River RSA)
Old 09-12-2007, 09:51 PM
brains's Avatar
Thanks Harry,I'll give it a go.
Ex Mooi River - where are you now?
Old 09-13-2007, 04:30 PM
Harry's Avatar
Smile
In New Zealand
Old 09-17-2007, 08:17 AM
brains's Avatar
NZ looks like there is some nice riding there by looking at my bother in laws pictures.
The cold start method - no throttle works like a charm, just have to get rid of the old habit of giving it a twist first.
Thanks
Old 09-17-2007, 03:13 PM
Harry's Avatar
Smile
Happy to be of help, look me up if ever you are in this neck of the woods.
Old 09-18-2007, 09:05 AM
cdn280 cdn280 is offline
I'd bet your pilot/slide/needle are on the rich side. Mine used to take a hefty boot to fire until I started leaning down the pilot (and main 1 size). It was much better, but now with the LTR needle it takes a light hearted prod to fire on the first or second kick (when cold, 1 when warm) and the choke can come off after a couple seconds. No more choke on/off fiddling while warming up.
Old 09-20-2007, 02:50 PM
rrguy's Avatar
rrguy rrguy is offline
Just from my little experience, but if it is tough to start cold, as the temp drops. I usually bump up the pilot. It is also a good idea to bump up the main if getting run hard & going from 80 degree weather to 40 degree. Actually there is a rule of thumb for every 10 degrees, but some carbs compensate better. Then go back down when the outside temp warms up. I am sure kicking it over real slow twice would help that situation out in more ways than one.
Old 09-20-2007, 08:44 PM
Treesmacker Treesmacker is offline
Put the bike in second gear and rock it back and forth a few times. The piston will suck a nice change of fuel into the cylinder and will start in the first or second kick. I trick I learned from a old timer!
Old 09-24-2007, 08:18 AM
widebear's Avatar
widebear widebear is offline
Banned
And what kind of condition are your reeds in?
Thread Tools
Display Modes
A little cold in Minnesota? webmaster General Discussions & Announcements 11 12-13-2009 04:20 PM
jetting for cold weather.. stainlesscycle Enduro Intake/Carburetion - 2 stroke 1 10-01-2009 08:42 AM
Hard cold start rupecopp Enduro Engine - 2 stroke 8 11-30-2008 10:54 AM
Cold weather - what to do?? 3hunerd Enduro Intake/Carburetion - 2 stroke 8 01-21-2008 11:50 PM
'05 FSE won't start when its cold. AAARRRGGG! cobrad Enduro Engine 4 stroke (including EFI & Exhaust) 6 05-13-2007 08:37 AM
