2007 to 2011 Frame Compatabity
I apologize for asking this question since it looks to be all but answered in a recent thread, but...I could use just a little more reassurance that I am not setting myself up.
I am sereously considering swapping the frame out on my 2007 300 for an 2011 frame. Other than plastics is there anything that I will not be able to swap between the two years such as triple clamps, subframe, swing arm, rear brake...the only thing that I could really come up with are the plastics (air box & frame guards) Thanks, Matthew
Believe nothing, no matter where you read it or who has said it, not even if I have said it, unless it agrees with your own reason and your own common sense. [Buddha] Last edited by smallpuffydog; 05-10-2013 at 04:05 PM. |
Believe nothing, no matter where you read it or who has said it, not even if I have said it, unless it agrees with your own reason and your own common sense. [Buddha] |
If you have a damper tower it will not fit as the steering neck is smaller on the '11 frame.
Sent from my iPad using Tapatalk HD |
No issue with the damper (I dont run one). I'll have to check part numbers to make sure that the bearings in head set are compatible.
Thread Tools | |
Display Modes | |
Seat mount 2007 - 2011 | Jakobi | Enduro Chassis & Body | 6 | 02-06-2013 09:32 AM |
Powdercoating the Frame on a 2011 | andykr87 | Enduro Chassis & Body | 19 | 12-10-2012 07:39 AM |
2011 Engine / Frame alignment question | rxmx | Enduro Chassis & Body | 1 | 04-22-2012 11:30 AM |
