EC200 died on straight gas with no premix oil.
I am considering buying a 2004 EC200 that was run on straight gas with no oil premix. The owner replaced the piston and said the cylinder was ok but the crank bottom end is making noise.
I am thinking that I should be able to fix it with new crank bearings and rod kit. I estimate about $425 for the parts and gasket kit. Does this seem like a reasonable assumption? Anything else I should watch for? |
I budgeted about $1000 for complete rebuild of a ktm 200 including replating the cylinder and cutting the head. So your estimate sounds about right.
2011 GasGas ec300R 2011 GasGas ec200 Six Days |
Don't trust what you were told, only trust what you can prove. Pull the head and cylinder, if possible, before buying. A complete rebuild, top to bottom, was $800 in parts for me. That is every moving part and gasket, including piston and rod kit. Yes you can rebuild just the crank for less than $500, but don't be surprised if you have to spend another $300 on a replate of the cylinder.
Not trying to be overly dramatic, just be prepared for any eventuality. If the bike is cheap enough, $1000 in a complete rebuild is a worthy investment (if done right the first time).
Phil (New bike pending...) |
Thanks for the suggestinos. Trust but verify, sounds like the way to go. It may be a challenge to get the seller to let me open his engine. I may be able to borrow one of those video bore scopes and check through the exhaust port to get a better idea of the cylinder condition.
Are there any known issues with the 2004 EC200s that I should watch for? Thank you |
At least pop off the exhaust and check the piston for visible signs of scoring. If possible, pop off the reeds, too, and check there. If there is any damage, it should show through the ports. If the intake and exhaust side (especially exhaust, it's the hottest) then it should be close enough to run as-is.
parts
ive got a 200 crank & rod assy. and piston if you need, if interested lmk
Stoby |
Pull the head, easy way to check the jug.... cycle through a stroke.....Heck, if the bike is cheap...you gotta split the cases any way....I see a full rebuild in your future Then you know she's solid!
Rick 99 EC 200 06 RM 250 AMA D36 375X OTHG 375S ***Thanks for the support : Twin Air /O'Neil Racing / Race 100% / Matrix Concepts / ODI / Mika Metals |
All good info. I will check it out tomorrow and if I can get it for reasonable $ I will add one more to the corral. More to come!
Price needs to be under $1k
"Less than $1k" before or after parts?
So I can work backwords, what is a fair price for a clean complete 2004 EC200 that is in running condition? |
Thread Tools | |
Display Modes | |
2013 straight out of the box - UK | Biff | Enduro Intake/Carburetion - 2 stroke | 42 | 06-12-2013 01:55 AM |
2004 ec300 died newbie helpp!!!!! | jt633 | Enduro Electrical & Wiring | 1 | 03-05-2013 04:00 AM |
2008 motor in 2004 Frame...is it a straight swap ?? | DaveH | Enduro Engine - 2 stroke | 10 | 01-14-2012 04:49 AM |
Premix 1:60 | sasa | Enduro Intake/Carburetion - 2 stroke | 6 | 11-15-2011 07:41 AM |
premix | W8TSON | Enduro Engine - 2 stroke | 31 | 08-11-2009 09:52 AM |
