Got this pipe in some extras with a 2011 ec250.
Pipe part number B12600100K I've googled, searched this site and tried searching all the online gasgas parts manuals and can't find any conclusive answer. So far possibly came on 2007 ec200. May actually be a 250/300 pipe.
2011 GasGas ec300R 2011 GasGas ec200 Six Days |
B12600100K is unknown to me. B12600100H is pipe with catalytic converter.
There is no such thing as bad weather! Only riding gear is improper or insufficient ![]() When it hurts you know you're allive! Gas Gas EC 300 Factory Racing 2012 - Ohlins TTX both front and rear - Rekluse Core EXP 2.0 + Rekluse clutch basket - Scalvini full exhaust system - S3 Head - Trusty adjustable PV cover That was ultimate setup for me... Now trying something else for a while... |
Probably the pipe with the cat in it, shove something in it and see if it is obstructed. That would be an easy way to tell. If it is I have a post somewhere on here of me cutting it open and removing it. It's the same demension as the stock pipe so if you can get it re welded you can use it as a spare like I did!
trevor |
![]() Quote:
![]() Quote:
Mine does NOT have an air tube, is silver colored and as far as I can tell there is no cat inside. What year/model bike did the B12600100H pipe come on?
Most GG part numbers for the frame, plastics or exhaust start with a BE then the number, typically 25 means 250. 30 is 300 and 12 would be a 125. The next set of numbers id the year it was first used...... It could be a vendor # though and won't follow that pattern
Fred Overstreet 2010 EC250 SixDays 2004 GasGas EC300 -Sold to a good home 2006 GasGas EC250-Sold to a good home 2006 GasGas TXT 280 Pro ![]() |
-07 euro model
I own a 2007 Ec200 Hobby, and that is the part number of the pipe that is on it . I'm trying to find out what FMF pipe I would need in order to properly replace this pipe . (B12600100K) .
Thread Tools | |
Display Modes | |
vforce replacement reed part number? | stainlesscycle | Enduro Intake/Carburetion - 2 stroke | 0 | 10-24-2012 04:45 AM |
Moose front sprocket part number | 3hunerd | Enduro Chassis & Body | 0 | 02-26-2012 04:26 PM |
Front wheel bearings part number | quazi-moto | General Discussions & Announcements | 7 | 04-10-2011 06:46 PM |
YZ Kickstarter part number does not work. | KicksonR66 | Enduro Chassis & Body | 3 | 10-27-2010 08:35 AM |
Combo switch part number | Ud_luz | Enduro Electrical & Wiring | 0 | 04-07-2008 06:26 PM |
