2014 xc250 leaking fuel
Bike is leaking fuel out of overflow. Bike is stock. Do you guys suppose its just dirt in the carb and need to be cleaned out. It started after I got back from riding on Sunday.
Yeah, I think they all do after a couple rides. Clean the carb out, set the float level and add a inline fuel fliter. It will be good to go after that.
15 GASGAS EC 250 19 Sherco SE 125R |
Could be some grit, gummed up a little, or float heights out. I always run an inline filter between the tank and carb, and take the time to set the floats before starting down the jetting path.
Mine did the same thing at the trailhead on my second time out on it. I smacked the float bowl with my boot a few times and it stopped. I did go back and clean the carb and set the float height later on though.
2013 GasGas XC300E 2005 YZ290 1973 Honda CB175 1997 KX60 1983 Yami Tri-Zinger 1984 Suzuki Alt 50 1969 Trail 90 1971 Trail 90 1972 Trail 90 |
Thread Tools | |
Display Modes | |
2012 XC250/300 fuel tap | Weird Rooster | Enduro Chassis & Body | 3 | 08-12-2014 07:18 AM |
2014 GasGas XC250 Kickstart - Fully Prepped | twowheels | New Bikes | 1 | 05-26-2014 02:47 PM |
The 2014 KTM 2strokes are fuel injected | Malcolm | All Other Bikes... | 5 | 06-04-2012 05:30 PM |
Fuel Leaking | Stef | Enduro Intake/Carburetion - 2 stroke | 9 | 10-27-2010 07:51 AM |
Leaking fuel lines. | Metalefty | Enduro Engine 4 stroke (including EFI & Exhaust) | 5 | 10-28-2009 09:50 PM |
