Old 08-25-2006, 12:27 AM
flybars flybars is offline
Default '05fse450 has no kill switch
Do not understand why this bike with all the dualsport electronics doesn't have a kill switch.
It has the identical starter button has the '05 Ktm. Also Ktm has a matching kill switch button. So I'll go with Ktm kill switch.
It's probly a real easy install, but a photo and instructions would sure help.Thanks alot, Bob
'14 Beta 300rr
'05 GG DE300
'03 GG EC250
'01 XR440
'09 FZ1
Old 08-25-2006, 06:44 AM
cdn280 cdn280 is offline
Are you sure you don't have a yellow? button on the top of the turn signal housing on the left handlebar ? Its kinda hard to press in.
edit: sorry, I was going from bad memory. Yellow is the horn. The kill switch is grey and on the top/backside of the same signal housing. It doesn't have a lot of off/on feel, but if you push it hard enough it works.
Old 08-25-2006, 05:34 PM
Thanks Cnd280. But I don't have grey button anywhere on the'05fse450.
The only switch that would have worked is the spring toggle button thing (black) on left front just ahead of horn switch. But it just lights up the headlight when pushed in, then shuts them off when u let up and labeled (lap). Thanks, Bob
'14 Beta 300rr
'05 GG DE300
'03 GG EC250
'01 XR440
'09 FZ1
Old 08-25-2006, 08:32 PM
MattR's Avatar
MattR MattR is offline
I'm curious why the 4T bikes don't have a kill switch? I looked in the 2005 and 2007 FSE manuals, but the left handlebar switch is not discussed. Only the key ignition is discussed for on/off. Would a kill switch cause an issue with the EFI system?
Matt
Current: 2009 Yamaha FZ1
Old 03-01-2009, 03:03 PM
iancp5's Avatar
iancp5 iancp5 is offline
I wondered this. I suspect there are too many things that need switching off. Simply killing the engine would leave the fuel pump running. But ... surely a rocker type like road bikes could be used rather than a press and hold? It could just kill all power via a relay?
Old 03-01-2009, 04:13 PM
Bearman's Avatar
Bearman Bearman is offline
We've got an '06 450 at our place at the moment. It has a kill switch? Where the starter button is, there is a red button above it, which allows the engine to be shutdown with the key still on. However the speedo or anything doesnt run without the engine running. You guys dont have this red button??
Ben
'03 GasGas EC200 My bike
'89 Yamaha TT250 R.I.P - Lost in the Black Saturday Fires
Old 03-01-2009, 07:49 PM
cal_tony cal_tony is offline
Re. My 04 450 FSE.
It also doesn't have a kill switch but it does have the same sw as discussed above. This switch turns the lights on and off. Surprisingly, my manual indicates that I do have a kill switch and it further indicates that I should use the kill switch to stop the motor because using the key to kill the motor could damage the EFI.
My 04 manual also indicates that I have a choke button for cold starting. Of course I don't but it would be nice since my bike on occasion does not like to start in cold weather.
So, just another of those GG mysteries.
Tony
Old 03-01-2009, 11:53 PM
coolum74 coolum74 is offline
Hope this isn't off track but my 06' is the same. You can leave the key on as long as you want and it doesn't seem to flatten the battery.
All other componets on the bike are shut down as soon as the kill switch is engaged.
Hope this helps
Adam
Adam
2006 FSE450...Gone
2011 EC300e
Sunshine Coast, Queensland
Australia
Old 03-02-2009, 04:43 AM
iancp5's Avatar
Nope not on my 06. No kill switch! Think one day I might rig one up but having just bought it there are more pressing matters to sort.
By the way anyone know what the resistance changes of the oil pressure sensor / sender should be?
Old 03-02-2009, 04:45 AM
iancp5's Avatar
Why does it run Windows?
Thread Tools
Display Modes
kill switch extending? lordfeyr Enduro Electrical & Wiring 3 01-14-2010 06:50 PM
1999 TXT270 kill switch SpeedyManiac Enduro Electrical & Wiring 4 06-25-2009 07:33 PM
Billet kill switch gasgasman Enduro Product Reviews 1 03-29-2009 12:01 AM
Kill Switch Dingo Enduro Electrical & Wiring 4 12-10-2008 04:23 PM
06 Txt250pro - Kill Switch? monkey8414 Enduro Electrical & Wiring 0 01-15-2007 04:16 PM
