Old 08-27-2006, 10:35 AM
24779819 24779819 is offline
Unhappy Help Me With My 200ec Please.
Hi I am new to the two strokes. I have just bought an 04 gas gas 200 ec for the tracks. Been out today and I'm having problems.
1. The bike will not idle. I have wound the screw on the carb in and no diffeance.
2. When I put the bike into gear and pull the clutch in it seems to be dragging ie if you push the bike in neutral it is easy to push. put it in first and pull in the clutch and it is very difficult.
Please help
Paul (24779819):
Old 08-27-2006, 02:36 PM
MattR's Avatar
MattR MattR is offline
Paul,
Check out the posts in the Engine and Carb sections for 2-strokes. There's a couple on the 250 and 300 bikes, but the same applies for the 200.
Matt
Current: 2009 Yamaha FZ1
Old 08-27-2006, 06:15 PM
barkeater's Avatar
barkeater barkeater is offline
Without being there to see what up... I don't think you have a carb problem.
The idle problem may be due to the dragging. My current '03 200 (and the '01 250 I had prior) had dragging clutch problems. When I'd come to a stop and have the clutch in full, the bike would creep forward, sputter and die before I could find neutral.
My guess is there is too heavy of a lubricant in the case and the adjusting screw on the clutch lever is too far in. (On a side note, any PTFE additives wreak havoc with the GG transmission as well, white goo builds up in the nooks and crannies and can cause the scorpion to stick - effectively stranding you in one gear until repaired, and while not a case splitting event, it's a pain.)
For a while, I ran AMSoil 0w40 and ATF (ford) at a ratio of 50/50 and that reduced the drag to a tolerable level.
I now run 100% Chevron Delo 400 15w40 (same as Shell Rotella), adjusted the screw on the clutch lever out a bit and now I have no problems, the bike will idle in gear, with the clutch pulled in all day.
As for any carb problems, clean it real good and put in the LTR jet kit if you don't already have it.
Old 08-27-2006, 07:34 PM
Brian VT Brian VT is offline
Here's some good info: http://www.gasgas.com/Pages/Technical/Clutch-drag.html
Old 08-27-2006, 10:05 PM
barkeater's Avatar
Hey, here's some more info.
Homegrown and fresh, right from Gas Gas Rider!
Seems we have a duplicate thread.
http://www.gasgasrider.org/forum/showthread.php?t=172
Thread Tools
Display Modes
200EC won't idle. Fred General Discussions & Announcements 3 06-24-2008 08:18 AM
200ec or 300ec for intermediate dad? firffighter Enduro Engine - 2 stroke 20 06-18-2008 09:29 PM
Vforce for 200ec RayGas Enduro Intake/Carburetion - 2 stroke 1 01-14-2008 04:03 PM
