EC250 aftermarket kill button
Hi!
After I went DC for my ec250 07 I have a problem with the connection of a new aftermarket kill switch/button. According to the wiring diagram of the manual the oem kill switch is connected via the horn (grey wire) to the yelow wire (AC power). The Yellow/Green wire to Black wire (ground) of the harness. I disconnected the horn when I bought the bike and the oem kill switch was still working. I connected the new kill switch in the same way but it does not work. The bike starts but the kill button doesn't kill it. Should I keep the one connection to the black wire of the harness and connect the 2nd wire of the kill switch to the White/Blue wire of the coil? I saw that I could disconnect this wire easily and replace the simple connector with a "double" connector so that the 2nd wire of the kill button can be connected there. Is this the way the kill button is attached on the DE models that I think they don't have the wiring harness of the EC model? I am waiting for your replies! Thank you! |
Nobody can answer this question? Is it ok to connect the kill switch to the White/Blue wire going from the CDI to the coil? I am asking first in order not to damage the CDI.
Regards, Leon |
There seems to be an error on the gasgas electric schema. The horn is connected to the CDI and the oem kill button to the horn. So, for two days I have been using the horn to shut off the engine...
Best Regards, Leon |
Thread Tools | |
Display Modes | |
2010 EC250 4T Aftermarket Exhaust Compatibility | Jeffro | General Discussions & Announcements | 3 | 10-27-2009 04:45 AM |
Billet kill switch | gasgasman | Enduro Product Reviews | 1 | 03-29-2009 12:01 AM |
Kill Switch | Dingo | Enduro Electrical & Wiring | 4 | 12-10-2008 04:23 PM |
06 Txt250pro - Kill Switch? | monkey8414 | Enduro Electrical & Wiring | 0 | 01-15-2007 04:16 PM |
