Old 05-13-2016, 07:07 AM
rosco's Avatar
rosco rosco is offline
Default 2011 ec125 Six Days compression?
Does anyone know what stock compression would be on the 125's. I know the 300's run around 175lbs. I'm only getting about 135lbs on this new 125. Seems pretty low to me. Pulled the pipe, the cylinder and piston look like new. Thanks! Ross
Rosco's Motorcycle and ATV
Rapid City, South Dakota
www.roscosmotorcycle.com
Old 05-13-2016, 08:28 AM
barossi73's Avatar
Check your tester on another bike and compare or retest.comp guages are notorious for variation and a vague tool for 2t.
If you have the pipe off,look for signs of blowby on piston.ie signs of combustion below the rings,the piston crown will look burnt/blackened.below rings should be pretty clean,except for blackened area just below rings on the exhaust side as its exposed to burn when port is partially open and rings are at mid port.
If its blackened way down further combustion is getting past rings.
Looking at a piston that i pulled out of my 200 at 65hrs the 'normal' blackened area is more or less horizontal and extends approx 10mm below the bottom ring on the exhaust port face.
Note.the piston was not worn out,comp was still good,no blowby.in hindsight could have run 100hrs easy(200)
You can slowly turn piston over with flywheel by hand with spark plug removed and view thru exhaust port
2013 ec200r
Old 05-13-2016, 10:31 AM
Elvis74 Elvis74 is offline
The squish on the 125 should be around 1,2mm
Gesendet von iPhone mit Tapatalk
4 strokes are only good for power generators
Old 05-13-2016, 06:54 PM
Zrt1200 Zrt1200 is offline
More than likely your squish is out to lunch. I just did my 200 yesterday. My squish was 1.5mm to 2.5mm / .060" to .100" I recut it and now its at .045"/1.14MM.
Old 05-13-2016, 08:43 PM
rosco's Avatar
This is a new bike, piston and cylinder cross hatch look like new. Just trying to find the specs on compression. Surely these things must run more than 135 lbs. of compression. Thanks for the info but I was just curious if anyone has ever checked the compression on a good running 125 and what to expect from one.
Old 05-14-2016, 02:11 AM
No, sorry, I never checked it. When I think I have a problem with mine, I just pull the cylinder and check and or replace everything.
By the way, I am here one of only a hand full 125/144 riders. ;-)
Old 05-15-2016, 06:13 PM
Zman's Avatar
Zman Zman is offline
I just checked our 2002 125 and it is 150 PSI and I am wondering if that is low. I did notice 130 PSI cold and 150 PSI warm.
Old 05-16-2016, 12:20 PM
rosco's Avatar
Thanks Zman! That's the kind of info I was looking for. So is your bike running ok with that type of compression? This bike just runs like crap. Jetting doesn't seem to make any difference. Powervalve is working fine. It almost acts like it is hitting a rev limiter. Starts good, idles good, runs fine up to about 1/3rd throttle and then starts to dog out on power but will continue to rev to about 1/2 throttle or a little higher and then starts to cut out like a four stroke banging off of the rev limiter.
Old 05-16-2016, 02:07 PM
Give us some more information. Which jetting do you run. Gasgas has for some markets pipes with a catalytic converter, check with a wire or so it your pipe is free and open. Is everything else in good condition? How about the sealing rings of the crank shaft.
Old 05-16-2016, 02:48 PM
Usually low compression will show its face at low rpm. Hard starting, poor idling, weak response off idle.. but will still run around at higher rpms a-ok.
Thread Tools
Display Modes
2011 ec125 Six Days [Jetting] rosco Enduro Intake/Carburetion - 2 stroke 8 03-18-2017 09:21 PM
2011 ec125 Six Days rosco "Wanted to Buy" & "Want To Trade" 0 05-11-2016 10:31 PM
Getting 2011 EC125 Street Plated rvangeel General Discussions & Announcements 1 11-12-2015 08:39 PM
2011 EC125 Six Days parts on E-Bay nknudsen Parts 5 10-17-2014 04:06 PM
2011 300 Six Days Synergy-Seals Used Bikes 7 07-24-2013 12:19 AM
