Strange air leak in ignition cavity
This may be a case of "If it hurts, don't do it!"
I have a '06 EC300. I've modified the ignition cover so that the drain (fill ) hole on the bottom is plugged and there's a hose nipple on the top. A hose is connected from the nipple and is routed up in behind the rads. As a test, I blew into the hose and I could hear air hissing out somewhere in the vacinity of the spark plug, head, or exhaust port. Would you expect that? I would have thought the ignition cavity would be sealed off from the engine crankcase. Or perhaps the seal is designed to only work with the crank at a higher pressure than the ignition cavity? But doesn't the crank cavity pressure go negative during the intake stroke? I need to more precisely identify where/if I'm hearing a leak. But I sure would appreciate it if someone could say "Ya, that's normal". And I'm experiencing no engine problems, or oil in the ignition cavity, etc. Again, perhaps I simply shouldn't be blowing into the ignition cavity. Thanks Dale |
Hmm you'd hope there wasn't a path from ignition case to head? After all you need the crankcase reasonably well sealed but ... if you're pumping air in at high pressure maybe you'd expect a slight leak as maybe the seals will pass some air in the wrong direction. If have enough pressure somethings going to give eventually. You sure it's not poor hearing though?
Perhaps through the wiring harness sheath, where it ends near the head under the tank?
+1 on the wiring harness sheath.
Matt Current: 2009 Yamaha FZ1 Previous: 2001 GasGas TXT280, 2001 GasGas XC250, 2004 KTM 200EXC, 2007 GasGas EC250, 2007 Husqvarna SM610, 2008 Husqvarna WB165 |
What a Homer (Simpson) I am.
The wiring harness was the source. I guess if I had just used my brain rather than my typing fingers I would have solved the problem hours ago. Thanks to Glenn and Matt for their knowledgable responses. Your Super Moderator status are deserved. Dale |
Thread Tools | |
Display Modes | |
Strange electrical problem | GMP | Enduro Electrical & Wiring | 14 | 12-14-2010 08:25 AM |
Strange Problem With My Gasgas Ec300 Am Ready To Burn It, | GasGas.ec300.Andy | Enduro Electrical & Wiring | 14 | 01-17-2009 07:59 PM |
06 EC300 - strange sound when over revved | colinmc400 | Enduro Intake/Carburetion - 2 stroke | 5 | 05-02-2008 12:10 PM |
No wonder my forks felt strange | JCW | Enduro Suspension | 2 | 12-01-2007 04:45 PM |
04 300EC Ignition changed to DE Ignition | Trail Blazer | Enduro Engine - 2 stroke | 0 | 01-08-2007 01:48 AM |
