Old 12-27-2016, 07:50 PM
bluespark's Avatar
bluespark bluespark is offline
Default 12' clutch cover on 11' ?
I took the metal clutch cover off my 11' 300 to replace the leaky POS plastic one on my 12' 300.
The plastic 12' cover has a molded nipple that hits the clutch push rod when I tried to fit it up to the 11'.
Can I grind off that nipple and still be able to use it back on the 12'?
I was going to try to slap it back together for some track time this weekend since the 12' is 3hrs away
Old 01-01-2017, 02:50 AM
Anders's Avatar
Anders Anders is offline
Yes I would think so.
Sent fra min E5603 via Tapatalk
Anders
1998 Bimota Supermono
1986 Duc Mille S2
1975 Guzzi sidecar hack
1961 Morini Corsaro 125
etc
Old 02-08-2017, 11:48 PM
Anyone tried the metal 2014 cover on the 2010/11 bikes
2003 txt250 Pro
2013 Ossa 280i
Old 02-09-2017, 11:52 AM
shang shang is offline
I put a '14 or '15 cover on my '13. It fit but I did have to grind the casting in the center down. Haven't had any problems after a season of riding.
2013 GasGas XC300E
2005 YZ290
1973 Honda CB175
1997 KX60
1983 Yami Tri-Zinger
1984 Suzuki Alt 50
1969 Trail 90
1971 Trail 90
1972 Trail 90
Old 02-09-2017, 02:13 PM
That's a bummer... the casting that directs oil into the centre of the clutch was the reason I bought it and the additional volume
2003 txt250 Pro
2013 Ossa 280i
Thread Tools
Display Modes
Clutch cover adv rider Enduro Engine - 2 stroke 7 07-29-2016 10:33 AM
Clutch cover ? biggstr6 Enduro Engine - 2 stroke 9 03-20-2012 09:58 PM
RMW Clutch Cover Rod Overstreet Enduro Product Reviews 2 01-24-2011 10:51 AM
