2018 choke
Has anybody modified the choke on a 2018? Some dirt got in between the lever and where it seats and was causing issues. Wondering what my options are
Delete the cable operated choke.
Anders "So you know, that you're over the hill when your mind makes a promise that your body can't fill" (Little Feat: Old Folks Boogie) 2015 EC200 Racing: TE bars, Rekluse Core Exp 3.0, 38mm Lectron & Ohlins S3 steering damper 2006 EC200: 2011 plastics, Rekluse Z-Start, revalved KYB forks & Scotts steering damper 1998 Bimota Supermono 1986 Duc Mille S2 1975 Guzzi sidecar hack 1961 Morini Corsaro 125 etc |
So take it out completely and run with no choke? Or delete and replace?
Replace cable choke with typical plunger type choke.
I actually enjoyed the cable choke but had to delete it due to the Lectron swap. |
Is there a specific model I need to get or can I get any choke plunger for a PWK 38mm ? Is there anything else that needs to be done internally to the carb other than unscrewing the old one and screwing in The new one? |
Current model YZ250 does the trick, but any from the same family of Keihin carbs will work.
14mm open ender, take out the old one, drop in the new one. |
2019 GG back to plunger!
'18 Gasgas XC250 |
My OEM choke has been a frustration since I got the bike. I had to return the lever all the way forward with my finger any time the lever was moved. Super frustrating a handful of times when shrubs grabbed it while I was boon docking around deadfalls from our recent heavy wind storms.
I went to take it off and put a standard plunger type on and was halfway through the process today when I realized I was missing a proper bushing to use my Magura clutch bolt from a 2018 Husky and I didn't have time to make one toda. In the process of reinstalling the OEM choke lever I realize it was installed wrong from uncrating. When I put it back on it is spring loaded and goes back to the closed position when you release your finger. I think I'm going to try it like that for a while and see if I can live with it now. Before it was very frustrating to me when I'd have to manually close it. |
1/2 your luck. I have a 2017 carb on my oldie which has the cable but nothing to connect to. I only use it once a day but pulling the end of a cable, whilst easy looks a little naff and I long for a lever like my mates have.
Grass is always greener huh?
'07 EC300 GG '14 TXT250 GG '? 496 CPI Cheetah RZ/RGV hybrid '22 765 Street Triple RS '21 XTrainer '69 Stinger T125 Suzuki '23 TRS 250RR (it's a Trials thing) |
Thread Tools | |
Display Modes | |
2018 - cable to plunger choke | Gibnut | Enduro Intake/Carburetion - 2 stroke | 0 | 03-17-2018 12:20 AM |
Choke replacement | Mostin3 | Enduro Intake/Carburetion - 2 stroke | 8 | 12-08-2017 07:17 PM |
Handle bar choke | Biff | Enduro Intake/Carburetion - 2 stroke | 4 | 06-16-2012 09:53 PM |
choke cable help???? | nambo-trev | Enduro Intake/Carburetion - 2 stroke | 2 | 08-27-2010 09:23 AM |
Cable choke for 03 250? | marjastaja | Enduro Intake/Carburetion - 2 stroke | 3 | 02-28-2010 09:45 AM |
