Old 01-16-2019, 04:36 PM
RudolfHucker's Avatar
RudolfHucker RudolfHucker is offline
Default 2018/2019 12v Power Connector
The 2018/2019 EC300 wiring diagramme (owner's manual page 16) shows a 12v power connector as part of the standard wiring loom. It is shown as "Salida 12v". I had assumed that it would be near the rhs radiator for a fan kit in the same way as KTM do. Trail Tech seem to supply wiring that connects directly to the battery for their fan kits.
Has anyone found one as I'll be damned if I can!
Old 01-16-2019, 09:41 PM
Quick look at the wiring diamgram. Appears to be the JST connector from the loom into the speedo unit.
Old 01-17-2019, 01:34 AM
Thanks, Jakobi,
I shall have another look and check with my voltmeter. It would be handy if it's up front as I want it for auxilliary led lights.
Old 01-19-2019, 05:58 AM
I have had a full check round and no sign at all near the speedo unit.
Old 01-20-2019, 02:08 AM
Undertow Undertow is offline
Hi
I guess it might be the power feed to the ECU unit. If it is the connector "O" that you a referring to, then it connects to the connector "C". And in the previous page there should be a diagram showing the connector "C" being the power feed to the ECU circuit...
Thread Tools
Display Modes
Swingarm Decals GG300 2018/2019 Doc Brown Enduro Chassis & Body 9 10-14-2019 10:18 AM
EC/GP 300 2018/2019 offset Doc Brown Enduro Suspension 2 09-03-2019 02:46 PM
will 2019 map switch fit 2018 Doc Brown Enduro Electrical & Wiring 13 12-27-2018 08:44 AM
Aftermarket Plastics for 2018/2019 EC Models RudolfHucker Enduro Chassis & Body 0 11-08-2018 07:12 AM
2018 XC 300 Power Valve adjustment Islander Enduro Engine - 2 stroke 3 07-11-2018 09:44 AM
