Old 05-15-2020, 07:25 AM
dANbOT's Avatar
dANbOT dANbOT is offline
Default 2014 clutch master HELP
Hey guys, I'm in panic mode right now.
Yesterday my clutch started feeling soft on my 2014 XC300RE, and I can see some fluid leaking past the seals on the clutch master. I need to get parts to make it functional ASAP. Losing riding days is a horrible prospect.
I've spent time searching, and from what I can tell, My master should be an AJP 9.5mm bore mineral oil.
Option 1: rebuild kit. I'm not seeing any in stock / available on this side of the planet (I'm in Canada)
Option 2: Can a more available master be swapped from a KTM?
I read mixed info on this. Sounds like the master end of my hose wouldn't connect to a KTM/Magura master? Would need the KTM hose?
Any advice would be greatly appreciated. There is a KTM dealer not too far away, if I could make something fit using the KTM parts, it would possibly be the fastest solution. Just not sure what to look for.
2021 Beta 300RR
2014 Gasgas XC300R
2019 850 Pro RMK
Old 05-15-2020, 07:37 AM
dANbOT's Avatar
If I am correct, this would be the appropriate rebuild kit for my master?
https://www.ebay.com/itm/AJP-MINERAL...IAAOSw49JevZK7
Shipping from the UK would put a huge dent in my spring riding season
2021 Beta 300RR
2014 Gasgas XC300R
2019 850 Pro RMK
Old 05-15-2020, 12:05 PM
gasgasman's Avatar
There are two different Magura master cylinders.
To be sure, the hose sealing ends will have to match up. The threaded part in the same.
This style one, I installed on my 2011 GG. Using the GG OEM hose.
https://www.ebay.com/itm/05-07-KTM-5...QAAOSwh3xer3Jd
On my '15. I used this style one, with the GG OEM hose.
https://www.ebay.com/itm/Magura-Clut...cAAOSws6tekauH
Old 05-16-2020, 06:32 AM
dANbOT's Avatar
Since one is mineral, and one is DOT fluid... I guess Id look at the mineral style you shared. Thanks very much!
2021 Beta 300RR
2014 Gasgas XC300R
2019 850 Pro RMK
Old 05-16-2020, 04:31 PM
hamilton's Avatar
hamilton hamilton is offline
This one fits my 15, with oem ajp master cyl.
Check hose part # for 14 & 15 should be the same.
Find someone close that has it in stock.
Stock on some ktm's ... thinking 14 200 maybe?
https://www.ebay.com/itm/Magura-2000....c100005.m1851
15 GASGAS EC 250
19 Sherco SE 125R
Old 05-16-2020, 09:13 PM
number9t number9t is offline
The ALL BALLS Racing kit #18-4003 worked in my 2014 EC300, its listed on the western power sports site as a 21-84003. Gasgas parts guy has them as well. When you rebuild it and go to bleed it, do yourself a favor and heat your oil before putting it in the master cylinder. I was having a heck of a time getting mine to bleed. It just kept pumping bubbles that would hang at the bottom of the master cylinder and then get sucked back down. When I heated up the whole cylinder with a heat gun, they all came to the top in no time. I wouldn't go crazy with the heat, maybe 120-150 degrees(american, not canadian degrees).
Old 05-17-2020, 05:34 AM
dANbOT's Avatar
Thanks for the pointers fellas.
My master cyl is dripping lightly, but I think I should be able to keep topping it off for the short term.
I ordered a rebuild kit from Mattos (blindly, no clue if / when it will arrive). But, I will probably want to convert to a KTM / Magura for easier to get parts down the road.
2021 Beta 300RR
2014 Gasgas XC300R
2019 850 Pro RMK
Thread Tools
Display Modes
Clutch master cyl cladoo "Wanted to Buy" & "Want To Trade" 0 10-27-2018 03:13 PM
2014 rear brake master cylinder 95jersey Enduro Chassis & Body 3 03-08-2016 12:58 PM
AJP clutch master desertgasser300 "Wanted to Buy" & "Want To Trade" 1 04-05-2013 10:34 AM
Help Please! Clutch Master Jakobi Enduro Chassis & Body 5 07-07-2011 08:46 PM
