Old 10-07-2020, 09:12 PM
Lozarus Lozarus is offline
Default New to gas gas. Ec300 doesn?t scream
Hiya new to gas gas. Only had 250f?s in the past and 125
2 strokes..
Got a 2010 Ec300. Just had a new top end. Load of compression and runs well.
Has loads of bottom end but just seems to lack top end like it doesn?t scream. Is this just a characteristic of this engine? I think it?s running pretty rich so am gonna do the jetting. Any particulatar brand to go for or are jets jets?I?ve checked the power valve all ok. Repacked exhaust etc
It feels like apart from the bottom end kick in the first few gears that it runs out of puff feels like a cr125 top end. Any pointers would be appreciated.
My understanding is That I can lift adjust the height of the main jet to lean it out some? At the moment if i lean the bike Right over fuel doesn?t come out of the overflow
Thanks for your help
Old 10-08-2020, 12:17 AM
(F5)'s Avatar
(F5) (F5) is offline
RM250 needle NEDJ
St N1FE is best cut in two so you aren't tempted to keep it.
Then find the right main circa 175
'07 EC300 GG
'14 TXT250 GG
'22 765 Street Triple RS
'21 XTrainer
'69 Stinger T125 Suzuki
Old 10-08-2020, 06:43 AM
Thanks dude il give it a try !
Old 10-08-2020, 09:50 PM
(F5)'s Avatar
My mate has a 10. We put that needle in. He scoffed as they look the same. Now he won't shut up about it. Try clip 2 from top but don't be afraid to experiment. Our gas / altitude will likely be slightly different.
'07 EC300 GG
'14 TXT250 GG
'21 XTrainer
Old 10-09-2020, 09:01 PM
Gasser Nate's Avatar
If you really want a screamer throw a N3CJ in there, has a more angry transition than the NEDW. I run the NEDW though as the N3CJ can get tiring.
Old 10-11-2020, 05:05 PM
agree, if you are looking for a more old-school 2t hit, then go for the N3** needle, the NE** will still scream, but it is much smoother getting there
2003 txt250 Pro
2013 Ossa 280i
Old 10-13-2020, 01:17 AM
Sdogg Sdogg is offline
Make sure choke circuit is closing completely, had the same issues and that?s what it ended up being.
Old 10-13-2020, 09:32 PM
Moto7man Moto7man is offline
Default My Specs
My specs below, see the jetting thread, 12 years of jetting info on that thread.
http://www.gasgasrider.org/forum/showthread.php?t=2162
Bike year & model = 2011 EC 300
Temperature = 90F+
Elevation (feet) = 0-100 ft
Main jet = 178
Pilot jet =40
Needle & notch = N3EG #3
Air screw setting = 1.5 out
Throttle valve/slide = stock
Stock head. V Force,Pwk II 38mm, Motul 710 40/1. Note: dealer had installed the ultra lean CHN needle which someone else posted was the needle used for emissions testing in Europe. Much more torquey off the bottom with just a little more hit in the mid and same top end rev out. On plug chop, good tan color.
Riding condition(engine load) deep sand.
―Comedian Lewis Black
-Unknown Sardaukar
Old 10-14-2020, 02:41 PM
good point, but i would think 10 years on, most of the cable chokes would have already presented these problems and have been replaced with the little on-carb button
2003 txt250 Pro
2013 Ossa 280i
Old 10-14-2020, 03:41 PM
If jetting alone does not achieve the top end range you are looking for you may consider some other options, such as 1) FMF fatty or PC expansion chamber 2)less pre-load on the power valve 3) exhaust port height/base gasket thickness
All of these options will have an affect on where the bike is making power, but with the 300 you may find that giving up a little on the bottom end of the power curve for faster revving/more over rev is worth it.
Thread Tools
Display Modes
UNI filter doesn't fit, WTF?! Why Z? Enduro Engine 4 stroke (including EFI & Exhaust) 7 05-29-2014 05:23 PM
My powervalve cam t thing doesn't look right rgranger Enduro Engine - 2 stroke 12 07-11-2011 12:41 PM
Why doesn't this work? Caravan Monster Enduro Electrical & Wiring 6 12-11-2010 12:48 PM
It doesn't fit.... stay_upright General Discussions & Announcements 7 03-04-2008 12:55 PM
