2015 gasgas 2T intake manifold too short
Hi
I was trying to fit the carb back on the bike, Until now I had aftermarket rubber piece that connects the carb to the reed side. I've wanted to change the aftermarket piece to OEM. when I tried to fit it the gap between the Reed and the carb was just too big for the OEM piece, and for the aftermarket one it just barely compensating for that gap... What am I missing here? |
Subframe bent?
Subframe looks good, no cracks or something.. all bolts fits easily in place
Do you have the rectangle top carb yeah? It's shorter than the old round top carb. When I put a 17 (or was advertised as 17 which likely earlier) carb on my 07 I had to make an extension to fit/bond to the carb..
Didn't look too far into what rubber bit was longer or whatever as 10 years between the frames. . But maybe?
'07 EC300 GG '14 TXT250 GG '? 496 CPI Cheetah RZ/RGV hybrid '22 765 Street Triple RS '21 XTrainer '69 Stinger T125 Suzuki '23 TRS 250RR (it's a Trials thing) |
i thought about making spacer that will go after the reeds, how did you made yours? |
I don't think in the big scheme of things you will notice. We had some tube the right size as the airbox side of carb. Turned off the ridge on the bellmouth end and sliding fit adapter like a big plumbing fitting. Bit of jb weld to be sure if no leak but was snug.
For anyone having this problem too
Turns out that the AS2 is 8 mm shorter then the AS1 carb, 91 vs 83 mm. Gas gas did nothing to compensate that gap between models with AS2 and AS1, Making it sometimes a nightmare to fit the carb back on. l've fixed that problem by mechining an 8 mm aluminum spacer to fit after the reeds (img attached) Works perfectly. |
Nice work!
Thread Tools | |
Display Modes | |
GasGas txt125 for short lady rider for Hard Enduro | FDB | Pictures & Videos | 4 | 05-18-2017 01:14 PM |
2015 GasGas | noobi | General Discussions & Announcements | 86 | 03-20-2016 09:22 PM |
2015 gasgas 450 | bkwdc | General Discussions & Announcements | 7 | 11-12-2014 02:09 AM |
Rubber Intake Manifold EC300 | prunty | Enduro Intake/Carburetion - 2 stroke | 2 | 07-27-2012 05:41 PM |
