Enduro Engine 4 stroke (including EFI & Exhaust) 4 stroke engine, EFI, and exhaust discussion |
Throttle position sensor adjustment?
According to the VSDST software from technoresearc, my tps only registers 59.7 degrees at WOT, 4.1 degrees at closed(idle).
Is this adjustable or is my tps bad and need replacement? |
After moving around and pushing the connectors for the tps and the ecu tps readings are now normal, 5.7 deg to 83.4 deg at WOT.
I wonder what resistance it has at Closed throttle compared to WOT..
"It's Nature that Brings out the Madness" GasGas FSR450 07' |
I used a cheap multi-meter and measured resistance. The tps is setup to deliver a voltage to the ecu, the potentiometer is supplied +5v and gnd, and center output is the metering circuit.
The resistance between gnd and output is 1.35 kOhms at idle, and 2.15 kOhms at wot |
Thread Tools | |
Display Modes | |
Handlebar mounting position | bchatt | Enduro Chassis & Body | 8 | 10-14-2010 05:34 AM |
neddle position Question | biggstr6 | Enduro Intake/Carburetion - 2 stroke | 8 | 05-12-2010 10:26 AM |
oil sensor 450fse 03 | jjbaker1 | Enduro Engine 4 stroke (including EFI & Exhaust) | 1 | 03-12-2009 05:54 AM |
Odo sensor on B/O | TooBadBrad | General Discussions & Announcements | 2 | 06-21-2007 07:23 PM |
Clip position ? | thingymijig | Enduro Intake/Carburetion - 2 stroke | 3 | 03-01-2007 04:57 AM |
