Looking for information to split case
Have to split cases on an 04 200ec can someone point me in the right direction to splitting the cases.
Also it appears that the nylon counter balance pieces unbolted and siezed the lower end is this common? Ray
RayGas 2019 GasGas 300 ec 2019 SWM RS500R Prunedale CA |
I know of 2 EC200's that this has happend to both being 1999's. 1 being mine and the other being my riding buddy. In his case the crank stuffer bolt came out and jammed between the rod and crank while riding. He split the cases and rebuilt the lower end.
On my bike, the same thing happended, I was starting my bike in the shop and it locked up. I was kicking it over I knew right away what had happend. I removed the topend, and bolt the bolt back in. I was able to fish out the bolt, I put loctite on the threads and re-install. I did the same to the rest of the stuffer bolts.
Rick 99 EC 200 06 RM 250 AMA D36 375X OTHG 375S ***Thanks for the support : Twin Air /O'Neil Racing / Race 100% / Matrix Concepts / ODI / Mika Metals |
splitting case
Mine is a little different, there was plastic everywhere???
I could not figure out where the plastic came from until I found a crankshaft breakdown apparently the counterbalance is made of a nylon derivative. I did not find any bolts (three bolts are supposed to hold it on) so I assume that they are in the bottom of the case somewhere. I found a manual to split the cases on the GasGas USA site and hope to split the cases this week. I will post when I split the cases and determine the extent of the damage. Ray
Thread Tools | |
Display Modes | |
The Tire Thread - Please add your information | noobi | Enduro Chassis & Body | 37 | 07-26-2021 12:17 AM |
Gearing Database - Please add your information | 2 strokes 4 life | Enduro Chassis & Body | 22 | 02-05-2018 12:59 AM |
Information please | NewB | GasGas Member Polls | 3 | 10-25-2007 09:36 PM |
2007 Model Information | jeffd | General Discussions & Announcements | 8 | 08-27-2006 01:52 PM |
FAQ Information Needed.... | webmaster | General Discussions & Announcements | 0 | 08-02-2006 11:28 AM |
