EC-400 FSE - Identifying Fuses
Hi,
Been looking through the manuals and can't find any reference to the fuse box. I have taken some pics and was wondering if someone could tell me what each fuse relates to(Numbered 1-8 in the pic. Also, I have this odd fuse in the box (number 7) which has no continuity across it however I have no idea what it relates to. Any help would be much appreciated: Fuse Box lid is scored, so I can't read what was on it!: Fuses 1-8 Mystery Fuse Number 7 - no continuity: Lastly - anyone know what the hell the fuses are supposed to bolt to? Looks like something should attached to the battery, but there is nothing there!?: Thanks Luke
2006 Triumph Daytona 675 2004 Gas Gas 400 FSE |
Ok, I think I have figured out the diode and it's purpose from the 2005 FSE 450 wiring diagram.
Well...? What?
Diode sits between the ECU and the solenoid and I think it is to prevent spikes. Continuity wasn't reading because voltage threshold was too low for diodes, though it has a diode setting which reads ok.
As for the rest of the fuses, I could go over all of them and figure out their purposes, but I was kind of hoping for a quick answer on here.
the internet is a karma bank. you give and thou shall receive the internets will thank you |
Thread Tools | |
Display Modes | |
